Sierra Grande Club
How do I install headers?
I wanted to test fit my headers these headers they are L 5423 hooker comp. the hooker guide says it fits blazer/jimmy/Yukon/tahoe 4x4 69-72. I don’t think there’s that much difference, but don’t know. Anyone?
Should I be able to put these on with the motor installed?
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
its all about the +6 inches
Re: How do I install headers?
yep.
Disconnect the battery, make sure your starter is installed and wired. Have an assistant help you out... a kid over 12 should be able to help. If I remember right, the passenger side has to come up from underneath, while the drivers side can come in from the top. Watch the engine oil dipstick...esp if it is on the passenger side. |
over the years i've found it helps to have an engine hoist handy and unbolt the engine stands so you can jiggle the engine a bit to get clearance it also helps to have it jacked up on jackstands so you can feed them straight down always disconnect battery and remove the starter too do drivers side first(more difficult)
Sierra Grande Club
That’s what I thought, I’m trying to get the d side in now, and it seems not to fit. Do you think that this being for a 4x4 and not a 2wd truck has anything to do with this?
And to save a little money--remove your plugs first. (also saves a few cuss words-lol).
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
Sierra Grande Club
Ok, it’s the driver’s side that’s giving me fits.
Do you think the 4x4 headers will work?
#7 | |
In Memoriam...
http://www.holley.com/search.asp They may fit, but likey would require some persuasion. Good Luck... ![]()
'68 C10 SWB 307ci 2BBL FarmTruk Pics Here "You know, doing what is right is easy. The problem is knowing what is right." |
unbolt the driver side engine tower then lift the engine GENTLY from the drivers side of intake manifold it will give you alot of clearance/you might also try sticking them up from the bottom
Sierra Grande Club
The headers don’t fit. They hit the “a” arm where it pivots.
Looks like I need to become a site supporter and see if anyone want to buy or trade. Oh well. s/t
interesting... My first headers (of an unknown brand) were off an 85 K/5.
Is it close enough that you can just dimple it? |
#11 | |
Sierra Grande Club
![]() Thanks for the suggestion though. s/t
#12 | |
![]() ![]() click HERE |
your truck is 2wd?
If you need them, i have a set of Hooker longtubes that have been sitting for the last 6 years in the box. I bought them for a project i no longer have. I'll go out now and look at the model number I was gonna throw these in the for sale section, but i'll give them to you cheap if you want them. PM me if interested.
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill Last edited by brak; 01-21-2007 at 09:25 PM. |
#14 | |
They are P/N 2452
Here's the link to them on summit's website Hooker 2452 Quote:
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill Last edited by brak; 01-21-2007 at 09:21 PM. |
#15 |
thats a great header..thats what i have on my 69
![]() Last edited by rage'nrat638; 07-12-2007 at 06:58 AM. |
