Old 01-23-2007, 06:04 AM   #1
67 cst swb
67 cst swb's Avatar
68/72 center links.... Question?
Are these center-links all the same. I have always just thought that 68-70 were different than 71-72's, due to the disc brakes... I even bought a 71-72 centerlink years ago from a guy (only $15.00) thinking I needed a 71-72 centerlink in order to put on all new 71-72 tie rods, etc.. onto factory 71 spindles... so that all would be 71-72 correct (I know I could have just upgraded to the 73-newer, but that wasn't what I did)
Any thoughts on this...?
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 01-23-2007, 06:21 AM   #2
uncle
Re: 68/72 center links.... Question?
71/72 is larger.
uncle is offline   Reply With Quote
Old 01-23-2007, 11:05 AM   #3
68speedalert
Semi-Senior Member
68speedalert's Avatar
You got what you needed. The center link isn't available new anywhere, there isn't any 'wear' related parts on it.....just a bar with holes in it. BTW, the holes are what is bigger compared to the 68.
'68 50th Anniversery LWB Custom Fleetside, '77 305 v-8, turbo 350, factory speed alert (still works), '71 drivetrain w/front discs. Some call it ugly yellow, others call it Ochre
'83 Jeep CJ-7, <80,000 miles, original owner
'04 Chevy Suburban, 4x4, 2500, 6.0 ltr, Predator Diablo programmer
'95 GMC K1500 Extended cab
68speedalert is offline   Reply With Quote
Old 01-23-2007, 11:09 AM   #4
Dr. Drop
The 71-72 center link is needed when you use the same year DB spindle. The reason is that the inner and outer tie rod ends only fit that center link. The 73 and up is not an interchange for the 71-72
Dr. Drop is offline   Reply With Quote
Old 02-04-2007, 06:36 PM   #5
67 cst swb
67 cst swb's Avatar
Ok, Good, sorta...
I bought a 71-72 Centerlink years ago. Only $15.00, but...
I was going to feel stupid if the 68-70's were the same... I now have about 4 71-72 cenerlinks from trucks parted out over the years...
My Trucks:
Old 02-05-2007, 12:12 AM   #6
SCOTI
SCOTI's Avatar
You can 'ream' the 67-70 drag links out to work w/the later model disc brakes too. Of course, if you can find a 71-72 drag link (or 73-87) that can be the easier option.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-05-2007, 02:24 AM   #7
Americanrider
So if I'm reading this correct 67 front end stuff is one-year only application parts? Meaning it will not interchange with 68-70 fronts. Anyone know why?
Sorry for the Hijack.
Americanrider is offline   Reply With Quote
Old 02-14-2007, 09:38 AM   #8
Stevie G
Okay, what's different on the 73 and up?
Stevie G is offline   Reply With Quote
Old 02-14-2007, 09:54 AM   #9
Joe67
67 is sold
Are the 67-72 drag links being reproduced?
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 02-14-2007, 01:35 PM   #10
stevess11
could you use the older inner rods and 71/72 outer to work with 72 spindles?
stevess11 is offline   Reply With Quote
Old 02-14-2007, 01:48 PM   #11
Aarons72s
American rider 67 is the same as 68-70. It is just the frame for the gear box is different. Other than that they are the same.
Joe67 No not reproduced at this time.
stevess11 Yes you are right but you have to get an adapter sleeve, someone posted where to get it but I dont rember.
Aarons72s is offline   Reply With Quote
