Old 05-05-2002, 04:54 PM   #1
David D.
Post coil problem
Hello,
I have ignition or charging circuit problems with my 68 C-10 Truck.
In fact, after a few minutes runing the coil become very hot,the engine stop and it's impossible to restart.
What do you think about this problem ?
What about to use a ballast resistor, my truck has no. Is stock truck have one ?
How to place it ?
I change the regulator by an old 64 Chevelle one, it seems to be the same, is it ok ?
Is there different type of external regulator on 68 V8 trucks ?
Thanks for your help.
David
David D. is offline   Reply With Quote
Old 05-05-2002, 04:59 PM   #2
Johns70
Johns70's Avatar
Post
i believe all the external regulators are all the same for chevy's and as for the coil getting hot that means bad coil, the chevy trucks use a built in ballast resistor in the coil or resistor wire from the fuse block i think. hope this helps
project 70 chev swb rebuilt 396bb{402}rebuilt th-400 3.73 limited slip 4/5 drop
69 chevy short wide box project
70 GMC jimmy project
Johns70 is offline   Reply With Quote
Old 05-05-2002, 05:04 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
Dave...first of all, welcome to the board from the center of the universe...well, center of Ohio anyways...Now, onto your troubles.
Are you running the old points, or you upgraded to an HEI yet? If you have points with the external coil, you NEED the resistor. If you have HEI, you need to remove the resistor.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
Andy, in Columbus Ohio
Old 05-05-2002, 05:06 PM   #4
68 Stepside
huh?
68 Stepside's Avatar
Post
David...coils are filled with oil to keep them cool. It's my guess that the oil has at some point leaked out of your coil, or there is an internal problem with the coil. In my honest opinion, I'd replace the coil, and I'll bet that takes care of your problem.
68
68 C10 Short Step (Christine), 406 SB, TH350, 3.73's, currently going on the back burner.
New to my fleet,
67 C10 Panel (1 of 3827) (Nicknamed the laggin wagon, thanks to Josh, the webmaster), 292, p/s, speed, 86,000 orig. miles
Gridley, IL
tjharvey68@hotmail.com
I'm on MSN messenger under that address if you would like to add me......
Also on AOL IM under the nick tommy85z
My Personal Homepage
The 67-72 gallery on MSN, feel free to submit your pics!
A pass-time of mine is storm spotting, click here to see Gridley IL's Emergency Services Homepage.
AOL SN- Tommy85z
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
