01-23-2007, 05:44 PM | #1 |
Everything is work in progress
NP205 rear output section swap out
My 80 GMC with a np205 has a slip style rear output section it. How hard is it and what is needed to change it out to except a yoke and u-joint?
I all ready have to do rear driveshaft work and u-joint work. Do I have to change the output shaft itself? thanks in advance
Good luck with your truck! How much?! It's just an old truck part!! 49 International on a 80 GMC 3/4ton 4x4 chassis 48 International KB-5 2 ton dump bed 04 Honda CRF "500" 09 Honda CRF450 fuel injected rocket 03 Suzuki hayabusa carbonfiber wheeled monster. 02 Ford diesel stretch van (toy hauler) 01 38' Monaco diesel pusher motorhome |
01-23-2007, 06:04 PM | #2 |
Re: NP205 rear output section swap out
I'm going to be doing this same change to one of my NP205's soon. I have a donner 205 that was from a standard truck, and I'm planning on swapping the rear output shaft and the bearing & seal housing as an assembly. I believe the slip shaft type housing is totally different.
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
01-23-2007, 07:29 PM | #3 |
I did this awhile back.
You'll have to swap the output shaft and the output housing. Here's my thread with a bunch of pics when I rebuilt my 205; http://67-72chevytrucks.com/vboard/s...d.php?t=193260
72 C20 4X4 454 4 speed 89 Trans Am (was) 305 TPI 700r4 93 C1500 2wd Extended cab 350 700r4 98 Sonoma (TPI outa the Trans Am) 03 Yamaha 660 Raptor 03/04 660 Raptor 07 700 Raptor 85 Honda Odyssey |
01-23-2007, 11:57 PM | #4 |
I knew I'd have to change the output housing, wasn't sure (in denial) about changing the output shaft. Will my gears and bearing fit the different shaft?
