Old 01-23-2007, 11:37 AM   #1
ProStreet68SB
The Engine Whisperer
ProStreet68SB's Avatar
17-Spline
Does anyone have an idea of when 17-spline center sections and axles were made? Will normal 12-bolt components will work with 17-splines?
thanks in advance
ProStreet68
ProStreet68SB is offline   Reply With Quote
Old 01-23-2007, 06:37 PM   #2
ProStreet68SB
Re: 17-Spline
ttt
Old 01-23-2007, 07:22 PM   #3
crazy longhorn
Fabricate till you "puke"
Re: 17-Spline
The 12 bolt has 30 splines......what has 17?
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 01-23-2007, 09:18 PM   #4
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Re: 17-Spline
The 12 bolt rearend in my truck. I am still digging up information on what year. I do know the guys that build rear ends know about the 17 spline units. I posted the same question over on the 60-66 board. I hope the reply.
I am going to go down and pull of the axel code and date tomorrow.
Some Vette's had 17 spline also according to Eaton.
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 01-24-2007, 03:40 AM   #5
1969 GMC
1969 GMC's Avatar
Re: 17-Spline
my eaton h072 has 17 spline shafts, never heard about the 12 bolt with them.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
