Can't ReMember
Trailer wiring harness
I have one hooked up, but haven't used it for quite awhile. Hooked a multimeter to it (don't have a trailer handy) and it shows 4 volts when the lights are on and 4 volts each time the light blinks.(4 prong plug testing each prong) Are 4 volts correct or should it read closer to 12 volts.
Adversity doesn't test your character; it reveals it. 71 C-10 LWB 350/TH350. I purchased it in 1978 for $1400. I'm currently abusing it daily. (when it's running ![]() |
Re: Trailer wiring harness
shouild be 12v at least
Can't ReMember
Thanks. I guess I should buy a new one and rewire. It's probably corroded at the clamp splice that was put on years ago.
those suck// they have plugin harness adatptors that you just plug in at the harness disconnect ifor the taillights just in front of the drivers side rear wheel// i think a trailer or boat supply store could get one for you
Can't ReMember
Ya, I was reading about them with the search function earlier. There was a Napa part number listed. I didn't quite understand how they worked, but with your explaination of the plug it has become clear.
![]() Thanks again, I'll check it out.
Can't ReMember
Okay, I was looking under the truck and I see where the harness has a plug going through the frame. So the adaptor goes here? Any trick to unplugging this? Just pull apart? Thanks.
![]() Join Date: Nov 2006
check your ground ........
Can't ReMember
I have all my tail light housings grounded to the truck with a seperate wire. I used the same ground that I use for this. When I tested the prongs I used the truck and the ground prong with the same results. Thanks, I will check the ground wires out when I get home.
Can't ReMember
Just got back from Napa. This adaptor is so cool. They changed the part number to BK7551554. $7.49
Thanks to this discussion and all the others I found in the search.
