Old 01-24-2007, 09:30 PM   #1
scottyjoe
Bb Headers........
I know this has probably been asked a ton of times but i cant find any info in the archives. i just put a 396 in my 1970 2wd. In doing so i moved the motor mount brackets back and aslo the tranny crossmember to make sure i have enough room for the bigger rad and electric fan. I used the STOCK 350 motor mount brackets and now i cant seem to find a set of headers to fit that clear the mount bracket. The front tube from cyl 1 hits. Do they make headers for a big block where the front tube comes up and over the rest (i know they make some like this for a small block) Thanks for any help!
scottyjoe is offline   Reply With Quote
Old 01-24-2007, 09:59 PM   #2
65-72 chevytoys
65-72 chevytoys's Avatar
Re: Bb Headers........
You need to use big block mounts to clear your headers or get a set of manifolds. Manifolds will clear the stock small block mounts.
2004 Chevy Silverado 1500LS SWB 5.3L
2004 Corvette Z16 #770
Wish I had not sold 72 blazer
65-72 chevytoys is offline   Reply With Quote
Old 01-24-2007, 10:00 PM   #3
65-72 chevytoys
BTW from FL
Old 01-24-2007, 10:09 PM   #4
scottyjoe
so nobody makes a set of headers for this application.....looks like im gonna be doin some fabricating. The motor mount i bought to fit a 396 in a 68-70 model cost like 80 BUCKS!! for one mount. Anyone ever tried shorty headers?
Old 01-24-2007, 10:31 PM   #5
Americanrider
Try looking at 4x4 headers, they are made to set back away from the mounts/crossmembers.
Americanrider is offline   Reply With Quote
Old 01-24-2007, 11:18 PM   #6
Inthuwind
Straight jacket required
Inthuwind's Avatar
Sanderson C5 headers may work.
1968 C10 Short Stepper
350/350 A/C P/S P/B Front disc
3/5 static/ 12bolt rear 3:73
1979 Pontiac Trans Am
10th Anniversary/455/4spd
2011 H-D Street Glide - CAMMED n lowered
Dad always said,"Son, if you can't be good...be good at it."
Inthuwind is offline   Reply With Quote
