![]() Join Date: Oct 2005
72 Cheyenne Build Thread
Thought I would finally sit down and compile my build progress pics into one thread.
Bought this truck in 1990 and it was my driver for about 6 years. I'm the 2nd owner of the truck and one of the main reasons I bought it was because it had original paint on it still....though I wasn't thrilled with the color, It grew on me. It is an original cheyenne, but the original owner ordered it with a "3 on the tree" which I promptly changed to a TH350 and a factory tilt column and then ordered a complete suspension kit fron So Low suspensions (stepped A arms, springs, shocks, and sway bars. I parked it in 97 and it sat for a couple years before I began to tear it apart. The first pics are of what I started with (front end off) and restoring the chassis. I have only a couple pics of the truck all together when I was driving it, but they are not in a digital format.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - ![]() My Build Thread |
Re: 72 Cheyenne Build Thread
Here's some more chassis pics.
The next pics are of the motor.
I really wanted to go with a late model fuel injection changover (I drool over you guys that are doing that), but a came across a great deal on the blower and aluminum heads from a friend that had bailed on a project (brand new). and then did some trade out work with a friend of mine that builds motors. The motor is the original 4 bolt block (040 over) with a Eagle forged stroker crank and H beam rods. Edelbrock RPM heads, scorpion 1.5 roller rockers, and an Isky custom grind blower cam. Pistons are forged SRP's. Moroso oil pan with a crank scraper and windage tray.
More engine pics.
The front drive is from Concept One. I had them make me a new bottom pulley for the blower. Good guys to work with and I recommend if your looking for a little less expension setup than many of the billet ones. I painted my alt and air compressor cast grey and clear coated it to offset having too much shiney stuff.
The next pics are of the cab.
I am only going with the factory lower moldings so I filled all the upper molding mount holes. Also relocated the tank to the rear and filled cab filler hole.
The next pics are of the fuel lid that I grafted into the bed. Found it off an old olds at the local pick & pull one day and also got the electric release that I will use as well.
The next pics are of the tailgate.
I ordered an aftermarket tailgate only because the inside of mine was so beat up. The new gate fit like crap so I decided to cut it up and just use the inside and graft it onto my gate. No pics of it finished but it turned out very nice.
The next pics are of the custom fuel cell that Fuelcellguy built for me. Someone pointed out to me that the front part of the step up may need to be vented which made sense, so I went to the local cycle shop and got a couple of those trick vents and installed them.....should work fine.
Misc pics.
The engine is now running and I can't seem to not go very long without having to crank it over and hear it sing!!
These are the latest pics.
The cab is on for good and just set the bed on as well after cutting and rubbing out both. I'm having a helluva time figuring what wheels to put on this think....right now I'm thinking Billet Specialties Vintecs. IT"S LOOKING LIKE A TRUCK AGAIN!!!!
Absolutely stunning work!!!! That is going to be one of the cleanest trucks I have seen. And its blown too!!!! You just can beat that.
Wheels, Foose Nitrous Gray, 18's up front, 20's out back. Those would be perfect with the color blue you have. Last edited by outlawc; 01-25-2007 at 03:26 AM. |
Beautiful!
What is your rear disc package? |
Hot Rods For Life
I could look a build threads like this all day.
![]() Join Date: Apr 2005
Project looks great! Interested in the rear disc brake kit also. Where did the rotors come from? Thanks,
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 01-25-2007 at 12:33 PM. |
#15 |
Looks like I was running on only 7 cylinders last night and posted this in the wrong place.....oh well.
The brakes are from Speedway. If I remember correctly (been awhile) I paid $399 for the kit. Came with everything...weld on brackets, caddy calipers, rotors and hats. Calipers were converted to std. instead of metric (brake line attachment). Also, the hats center opening had to be enlarged a little to fit the hub. Haven't had a chance yet to see how they work. It's been a few years since I did it and it seems there are more options for rear discs now.
#16 |
SLOW BUT SURE,BUT CLOSER
Wow!!!!!!!! What a change from the yellow!!! Super job
69 C-10, OWNED 38YRS... 350 over 30, 350 Turbo, 3:73 Posi P/S, P/B Black with red and black int. ''LOVE THESE OLD ''TRUCKS....... ![]() ![]() ![]() |
#17 |
Village Idiot....
Very nice work, truck is drop dead gorgeous.....You can't go wrong with Vintecs!
or course this is coming from a guy that's had four sets and just ordered another for his Rambler ![]() Last edited by n2billet; 08-28-2009 at 05:56 AM. |
#18 |
Broken Down
Awsome truck super nice work.
kenm78 1982 Chevy 4X4 Project truck ![]() ![]() ![]() ![]() “It’s better to keep your mouth shut and let people wonder about your ignorance, than open your mouth and reveal all doubt” |
#19 |
BlahBlahBlah
I like the vintage 200S wheels you have on there now...I wouldnt mind having a set of those lying around for a future project.
Oh, and your truck looks superb. |
#20 |
ive never liked the color blue more in my life than i do now..haha..what color blue is that anyway??? and thats a beautiful truck man i love it, nice work, how HP is that thing making?
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
#21 |
Sweet!
"The rays of light thru the Shiner Bock bottle make me wanna turn the key and put down the throttle...and get lost down 35" - Jason Boland www.YouTube.com/user/593Films - Watch My Videos! ![]() 1977 Silverado K10 2014 Dodge Durango (Wife-mobile) 2008 Dodge Ram Lone Star Edition (Daily driver) |
#22 |
![]() Join Date: Dec 2006
looks sweet! i like the gas door! any idea how hp much the motor will make?
#23 |
Thanks alot guys for the compliments. Seems this truck is taking a lot longer then I ever imagined and I tend to have good stretches of progress and longer stretches of no progress, but now I'm at the point where I'm seeing significant visual changes and the sound of the thing running which substantially adds to the motivation!!
N2Billet - A compliment from you is gold when I look at your red 68....makes me wanna sell my 72 front end and convert!! Could I see some pics of your vehicles with the Vintec's? There's a big part me that is struggling with putting a cast center type wheel on this thing...WHAT TO DO! CG - I love the 200S's that I have. but just want a bigger wheel/tire combo. Gonna sell em once I get the truck road worthy and after a few good burn outs with the old rubber. GreaseMonkey72 - The color is 99-00 Corvette Bright Blue or I've heard it referred to as Nassau Blue. ...as far as horsepower goes, I've seen a few tests in some of the mags that resulted in about 470 hp on a goodwrench small block 350 with aluminum heads and a mild cam. I have a few more cubes (388) and a little bigger lower pulley and should see about 6-7 lbs of boost, though the charge will be a little warmer because this baby blower has to spin so fast. I'm guessing anywhere from 500-550 hp, but the best part will be the massive amount of low end torque the roots style blowers are famous for. I just hope the 700r4 stays together!
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - ![]() My Build Thread Last edited by SactoJim; 01-26-2007 at 01:35 AM. |
#24 |
![]() Join Date: Sep 2000
That is going to be a nice truck.
72 Chevy short step side with 454 air and tilt. 72 nova project car 63 chevy II drag car Agency Iowa |
#25 |
awesome truck man!!!!
good job on the work! |
