![]() Join Date: Apr 2001
Re: power brakes upgrade for a 74 1/2 ton
pretty easy upgrade... but you need the booster (duh), brackets, and preferrably a new master cylinder for power brakes. When I did mine I got the pedal and rod asembly out of the same donor truck to make everything work. If you dont you will have to adjust or replace (cant remember) the rod because the manual brake rods and power brake rods are different sizes... someone on here will know for sure...
63 C20 2WD, 230/SM420/4.11 73K 68 C30 dump truck, 327,SM425,4.56 66K original 68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes 68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79 69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi... 70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP 72 Chevy K20 4x4 350/350/205/4.56 donor 72 Vette 350/M21/3.70 posi, triple black and super fast 84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's |
| Bookmarks |
