dash replacement, How To...
I have searched the FAQ section and I can't find specific info that will tell me how to replace my dash. There are photos of before and after and info about cutting through the holes, but I am trying to find the in-between stuff. After I remove the bolts on the end where do i cut. there are spot welds on each end. This is my daily driver so the windshield stays in and I don't want to screw it up. Any help would be appreciated. Oh yeah, the PO cut up the dash to install what looks like a Tv. I have a uncut A/C dash to replace it with so long as I don't screw it up.
Re: dash replacement, How To...
Sorry, it's a 67 stepside, short bed.
Who's got steelies?
![]() Join Date: Feb 2006
The windshield has to come out to remove the dash. After the windshield and seal comes out, you will be able to see the seam where the dash meets the top of the cowl. You will be able to see a bunch of little dimples along this seam, viewd from the outside. I used a 1/8" drill bit to drill through the dimples to remove the dash from my old cab. The dimples are the spotwelds that hold the two pieces together. Took maybe 20 minutes, and I broke a couple of drill bits doing it. It was very easy.
![]() ![]() ![]() ![]() ![]() ![]() How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
thanks for the help Oldgold, but the windshield has to stay in because she is my daily driver and if I break the windshield trying to remove/replace it...if I remember correctly, putter did somethig to his dash but i can't remember...putter!!! Without pictures I'm lost.
Once you remove the dash pad you will see a row of slots from one side to the other. You can trim the old dash on the slot line and "rig" the new dash with several sheet metal screws or a few tack welds. The "scar" is covered by the dash pad.
Good luck - Bob
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
