Old 01-25-2007, 07:59 PM   #1
myersjeremy
myersjeremy's Avatar
Best way to put on headers????
I am having a little difficulty getting my headers to go into place. Any nifty tricks to getting them on? I took the spark plugs out and it freed a little space up. Seems to catch on the frame every time.
Jeremy
myersjeremy is offline   Reply With Quote
Old 01-25-2007, 08:14 PM   #2
KMK454
KMK454's Avatar
Re: Best way to put on headers????
Where did you get your headers? I'm thinking of replacing mine with a newer, more modern set. Plus I suspect a leak or two...
Sorry I don't have any help
Kurt
Instagram: @kurtkphoto
1978 C10 Silverado
1991 Camaro B4C
KMK454 is offline   Reply With Quote
Old 01-25-2007, 08:27 PM   #3
84 400
Sb 400 club
84 400's Avatar
are you trying to go threw the top right? try going up from underneath the truck
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 01-25-2007, 09:34 PM   #4
84workhorse
drivers side from the bottom and Pass from the top. Start the farthest bolt back first then do the bolt all the way in the front.
84workhorse is offline   Reply With Quote
Old 01-25-2007, 11:37 PM   #5
dbcox
dbcox's Avatar
since your having such a hard time if you dont want any leaks get some orange rvt the heat type.run it around the flange in a nice bead and let it set up.tighten them up a ride around with no leaks. I havent used a gasket in about 8 years or more probably more that made me feel old.
dbcox is offline   Reply With Quote
Old 01-26-2007, 10:30 AM   #6
swb85
On a budget like Fred Sanford
swb85's Avatar
I've always had the best luck putting both sides in from the bottom, some brands really take some wiggling to get them to slide up there. Don't be afraid to get mean with it!!
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 01-26-2007, 11:49 AM   #7
redz 1970 K5
OBS guy
redz 1970 K5's Avatar
It takes the correct language too. Most people forget that. Colorful 'sentence enhancers' are usually the missing tool when a header will not go into place.
88 Suburban
Goodies- Alpine, Auto Meter, BDS, Bilstein, B&M, BFG, Borgeson, Bushwhacker, Cowl hood, Flowmaster, Genuine Gear,
Holley, Infinity, JVC, K&N, MB Wheels, MSD, Pioneer, Skyjacker, Sony, Thorley, Walker + more
redz 1970 K5 is offline   Reply With Quote
Old 01-26-2007, 02:24 PM   #8
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
^LOL, thats so true tough. Try coming up from the bottom if you have not already other then that just get mean with them but not overboard so nothing gets broke up.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 01-27-2007, 12:40 AM   #9
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
With my 1986 chevy c10 2 wheel drive. i tried from the top on the passanger side (which worked easy enough) and for the driver side i had to jack the truck up to get the room to put it in. Or another idea is to remove the hood undo the motor mounts and make the room (mostly cause the big power brake boosted got im my way). That 2 ideas that i have used in the past
Srubydo1986 is offline   Reply With Quote
Old 01-27-2007, 01:04 AM   #10
Big Ol'Chevy
I've always came up from the bottom of the truck, didn't matter if it was a 2wd or 4wd. Pull plugs and dipstick holder on driver side and plugs and starter on pass. side, they have always went in easy.
1972 Chevy K20
15" & 44's
1986 Chevy K30 Crew Cab Longbed
6" & 35's
Big Ol'Chevy is offline   Reply With Quote
Old 01-27-2007, 01:48 AM   #11
cliffsta
Stepsides RULE
cliffsta's Avatar
Sounds like our mechanicing styles are very similar!!!
Good luck with the headers... I've always wanted some headers and exhaust....
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD
1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD
1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD
2009 Kawasaki KLX-250S too many mods for this signature
1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake
Cardomain of the Accord
cliffsta is offline   Reply With Quote
