Old 01-25-2007, 04:07 PM   #1
pimperout
pimperout's Avatar
brake boosters
i found some old 73-87 trucks that my friends uncle is letting him part out and there are some brake boosters in em i was wondering if they will fit (probly not rite) if thats the case then how hard would they be to make them fit?
pimperout is offline   Reply With Quote
Old 01-25-2007, 04:44 PM   #2
gkolmatycki
Love that '69
Re: brake boosters
Don't quote me on this, but I believe you could make them work from the 1973-87 model year. You would need an adapter plate to mount the booster onto the firewall. Also, I think you may need another rod to go from the booster to the pedal, because the ones out of those trucks are the wrong length. There may be other things that I missed that someone else will add. I just bought a new one, but they cost about $150+
I AM CANADIAN & PROUD OF IT!!!
1969 Chevy C10, SBC V8, TH-350 Transmission, Metallic Blue, B&M Megashifter, GT Grant Steering Wheel, 2.25" True Dual Magnaflow Exhaust System w/ SS Magnaflow Embossed Tips, 700W Rockford Fosgate Stereo System, Lowered 1" Front & Stock Rear, 4.56 Rear with Positraction, 15" Chrome Rims w/ Chevy Center Caps & Michelin Tires, 4.5" K&N Air Filter, Edelbrock 'Elite' Engine Accessories, Chrome Powdercoated Engine Parts
2001 Cavalier Z24, 2.4L DOHC, Silver, Spoiler, AEM Intake, 2.25" Magnaflow Exhaust System, Clear Euro Tails, Tinted Windows, 400W Clarion Stereo System
gkolmatycki is offline   Reply With Quote
Old 01-25-2007, 04:47 PM   #3
70rs/ss
70rs/ss's Avatar
Re: brake boosters
I think he is correct, but get it and the rod and try it. I think you can use the bracket off your truck onto the newer master cylinder and your old rod. I just used a 3/4 ton booster from a 72 that way it is all the same except the 3/4ton have a dual diaphram (which is why I swapped, dual diaphram=better stopping with less peddle pressure)
70rs/ss is offline   Reply With Quote
Old 01-26-2007, 05:19 AM   #4
pimperout
pimperout's Avatar
Re: brake boosters
awsome thats guys
Old 01-26-2007, 05:31 AM   #5
pimperout
pimperout's Avatar
Re: brake boosters
haha wow i dunnno what i was typing up there thanks guys is what i was trying to say lol
Old 01-26-2007, 09:52 AM   #6
dave2953
Dave's not here, man
dave2953's Avatar
Re: brake boosters
I took a booster off from a 78 Scottsdale and had to modify several things to make it fit. The bracket was wrong, so it had to be modified. Also, in order for the booster rod to line up with the pedal assembly I had to notch the firewall where the rod passes through. The rod from the 78 was not long enough to reach the pedal assembly, so it had to be lengthened. And finally, the shouldered bolt that holds the rod to the pedal assembly was too large in diameter to fit through the rod for the 78. I had to grind the bolt hole slightly to allow clearance. Like an idiot, I never tested the booster before I did all this and it turned out that the booster diaphragm was leaking, so it all came back off. In short, this swap was a complete whore. I'm sure others have had much better success, and other years from 73-87 may have different brackets, rods, etc. Good luck with whatever you decide.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 01-28-2007, 04:06 AM   #7
pimperout
pimperout's Avatar
Re: brake boosters
alrite good info guys thx this board has yet to disappoint me
Old 01-28-2007, 09:14 AM   #8
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: brake boosters
Do a search in the FAQ section and you should find lots of info on what will and wont work.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 01-28-2007, 03:07 PM   #9
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
Re: brake boosters
There is some info on this topic in the threads below. In general, a little modification is required but they are a pretty easy retrofit.
http://67-72chevytrucks.com/vboard/s...d.php?t=215980
http://67-72chevytrucks.com/vboard/s...d.php?t=216515
1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD)
1978 Chevy C/10 SWB
1970 Pontiac Lemans
C10-Driver is offline   Reply With Quote
Old 01-28-2007, 05:55 PM   #10
pimperout
pimperout's Avatar
Re: brake boosters
thanks again good info
