Best way to put on headers????
I am having a little difficulty getting my headers to go into place. Any nifty tricks to getting them on? I took the spark plugs out and it freed a little space up. Seems to catch on the frame every time.
Thanks Jeremy |
Re: Best way to put on headers????
Where did you get your headers? I'm thinking of replacing mine with a newer, more modern set. Plus I suspect a leak or two...
Sorry I don't have any help ![]()
Kurt Instagram: @kurtkphoto 1978 C10 Silverado 1991 Camaro B4C |
Sb 400 club
are you trying to go threw the top right? try going up from underneath the truck
![]() ![]() 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed ![]() 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out Last edited by 84 400; 01-26-2007 at 04:56 PM. |
drivers side from the bottom and Pass from the top. Start the farthest bolt back first then do the bolt all the way in the front.
since your having such a hard time if you dont want any leaks get some orange rvt the heat type.run it around the flange in a nice bead and let it set up.tighten them up a ride around with no leaks. I havent used a gasket in about 8 years or more probably more that made me feel old.
On a budget like Fred Sanford
I've always had the best luck putting both sides in from the bottom, some brands really take some wiggling to get them to slide up there. Don't be afraid to get mean with it!!
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
OBS guy
It takes the correct language too. Most people forget that. Colorful 'sentence enhancers' are usually the missing tool when a header will not go into place.
88 Suburban Goodies- Alpine, Auto Meter, BDS, Bilstein, B&M, BFG, Borgeson, Bushwhacker, Cowl hood, Flowmaster, Genuine Gear, Holley, Infinity, JVC, K&N, MB Wheels, MSD, Pioneer, Skyjacker, Sony, Thorley, Walker + more |
Chevys Kick A$$
^LOL, thats so true tough. Try coming up from the bottom if you have not already other then that just get mean with them but not overboard so nothing gets broke up.
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
The Crazy Machanic
With my 1986 chevy c10 2 wheel drive. i tried from the top on the passanger side (which worked easy enough) and for the driver side i had to jack the truck up to get the room to put it in. Or another idea is to remove the hood undo the motor mounts and make the room (mostly cause the big power brake boosted got im my way). That 2 ideas that i have used in the past
I've always came up from the bottom of the truck, didn't matter if it was a 2wd or 4wd. Pull plugs and dipstick holder on driver side and plugs and starter on pass. side, they have always went in easy.
1972 Chevy K20 15" & 44's 1986 Chevy K30 Crew Cab Longbed 6" & 35's |
#11 | |
Stepsides RULE
Good luck with the headers... I've always wanted some headers and exhaust....
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD 1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD 1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD 2009 Kawasaki KLX-250S too many mods for this signature 1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake Cardomain of the Accord |
