Old 01-26-2007, 11:18 AM   #1
MR MAGOO
MR MAGOO's Avatar
Turbo 350 Tranny Problems
Can Anyone Tell Me Why My Turbo 350 Takes About 5 Minutes Before It Will Go In Gear On Cold Startups? Also Sometime Goes About 100' Then Stalls Again. Once Warmed Up It Is Fine. What Is The Deal With That??
MR MAGOO is offline   Reply With Quote
Old 01-26-2007, 02:22 PM   #2
kombreeze
Re: Turbo 350 Tranny Problems
Is the fluid fine? I had that same issue with my tranny but oddly when i finally tuned the engine correctly it seem to remedy it. Oh and I was a quart low in the tranny, I usually check it in drive with some one holding the brake.
kombreeze is offline   Reply With Quote
Old 01-26-2007, 02:47 PM   #3
71MUTT
Can't ReMember
71MUTT's Avatar
I've never heard of this. I've been checking my 71 in park after a 20 min drive for 29 years now. Seems to work okay. The tranny has 250,000 miles on it and I've only changed the fluid and filter once.
Adversity doesn't test your character; it reveals it.
71 C-10 LWB 350/TH350. I purchased it in 1978 for $1400. I'm currently abusing it daily. (when it's running )
71MUTT is offline   Reply With Quote
Old 01-26-2007, 06:12 PM   #4
cooters
turbo 350 trannys have 2 micro screens in them, if these plug up, with the colder thicker oil it can cause grief.
cooters is offline   Reply With Quote
Old 01-26-2007, 06:33 PM   #5
gator2511
gator2511's Avatar
My TH350 started doing the same thing. Once warmed up it ran fine. Its called morning sickness by the tranny shops around here. I was told it needed to be rebuilt. I replaced it with a TH400 and a Gear Vendors O.D. Sorry but I don't know anymore than that.
gator2511 is offline   Reply With Quote
Old 01-26-2007, 07:15 PM   #6
gouldie
my th400 used to do this. never actually fixed the problem but i thought it was a clogged screen. drop the pan and see if there is any residue on the bottom.
67 c10 250 I6 3 on the tree no options
air ride, paint and big block coming within the next 23 years
2001 mustang gt for going fast
gouldie is offline   Reply With Quote
Old 01-26-2007, 09:36 PM   #7
WorkinLonghorn
WorkinLonghorn's Avatar
Assuuming your fluid level is OK it sounds like the usual hardening seals.Warm it up good before you drive it and you may still get some good miles out of it.Drive it cold and slipping and you better start shopping around for a rebuilt.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
