01-23-2007, 04:04 PM | #1 |
Hot Rods For Life
Tell me about tanks for air setup
I assume I need at least a 5 gallon with 6 ports. What size for ports? 1/4, 1/2, 3/4, or 3/8?
01-23-2007, 04:20 PM | #2 |
Re: Tell me about tanks for air setup
The port size depends on what valve you are running. My tank has all 1/2" ports, so I just used bushings to step it down for the 1/4" compressor hose, 3/8" drain plug, 1/4" pressure switch.
The common setup seems to be 4 ports on the side for valve, a port on each end for compressors, a port on the bottom for drain, and a port somewhere for the pressure switch. A 5 gallon tank is good, any bigger and you will need 2 compressors. I have a 7 gallon tank and it's way too much for my single compressor now. I don't fill the tank, so it's not too bad. If you have 2 ViAir 380 compressors (a nice setup), you can run a 7 gallon tank, or even do dual tanks. It all comes down to what you want to run and where it fits. Here is a shot of mine mounted between the frame rails. The driver side is plugged, the drain on the bottom, compressor feed on the passenger side and the pressure switch on the back. |
01-23-2007, 07:42 PM | #3 |
Outlandish Trends - FL
Zumo, I am running (2) 3-gallon tanks and they are mounted on the outboard frame rails on either side just behind the cab. They are concealed nicely behind the bedsides so they cannot be seen. There's quite a few of us running that setup. The ones I bought are from ***************** and they have a 1/2" port on either end.
my setup is as follows: driver side tank: front port=compressors (I have a tee splitting them before the port), back port=rear fill valves passenger side tank: front port=1/2x1/4 bushing w/1/4" line to my tank gauge, and rear port I run up to my front valves. Hope this helps. P.S. - My Zumografix shirt is about worn out from over-use. Are you gonna have another shirt buy soon? I'm ready to buy!
-Bret 67 short-fleet sold! Last edited by 67Fleet; 01-23-2007 at 07:43 PM. |
01-25-2007, 07:34 PM | #4 |
Village Idiot....
Mine is set up a lot like 67 fleet except I mounted my compressors by the cab because I love the noise they make (wasn’t thinking at the time) and mounted my 2 tanks in the rear with the rest of the management system…..the picture will explain it better then me
01-25-2007, 11:31 PM | #5 |
My compressors are mounted where n2billet mounted the tanks, but on the inside of the frame. I mounted an led in the cab so I would know when they go on because I can't hear them with the engine running.
If I am sitting at a red light with the window down, I can sort of hear them. |
01-25-2007, 11:47 PM | #6 | |
Happy to be here
Andy here is the set up on my 77 Cheyenne.
01-25-2007, 11:52 PM | #7 |
Thomas 337's. They seems loud when you stand near it and the engine is off, but my ghetto Cherry Bombs overpower just about everything. When I get the new exhaust, it may be a lot more noticeable.
01-26-2007, 12:56 AM | #8 |
Im running 2- 5 gallon tanks and 2-viair 480's.
01-26-2007, 01:39 PM | #9 |
N2TRUX - Do you have it hard mounted to the frame? It's hard to tell with the pictures. If so, you could probably isolate it with some rubber bushings, which will reduce but not eliminate the noise. I'm sure the people that build these compressors are not worried about the noise level, they're only worried about the volume of air that they can compress. Larger volume usually = more noise.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
01-27-2007, 02:22 AM | #10 |
YORK is your answer for quiet fast filling. i a have one 8 galon, 8 1/2 inch port and running all 1/2 lines and valves, 1/4 pressure switch and two 1/4 drain plugs. and last but not least 1 huge helium tank
