Junior Member
How many CI do I have?
69 C10, with original 307 block - PO had it bored when it was rebuilt - but he's long gone and didn't know how much it was bored. So it's most likely what size? Can you bore a 307 out to 4 inches to make it a 327? Is that what most shops would do since the 327 pistons would be easy to find? Just curious. Trying to track down the rebuilder but so far no luck.
_______________________________________ 62 SWB BBW (under construction) 86 Vette Convertible |
![]() Join Date: Mar 2003
Re: How many CI do I have?
Probably went 30 over. which would make it about a 312
Never seen a 307 block that would go .125 over. They are thin wall casting blocks. I'm sure it's either .020,.030 or .040
In Memoriam...
Here's a good linky for 307 info...http://www.jalopyjournal.com/forum/s...ad.php?t=45615
'68 C10 SWB 307ci 2BBL FarmTruk Pics Here "You know, doing what is right is easy. The problem is knowing what is right." |
Chances are you went 30 over (312). i went 40 on my vette (350) and now its a 357
