01-28-2007, 10:13 AM | #1 |
Junior Member
Brake Light
Hi, I put some brake fluid into the rear portion of the master cylinder as it was very low or empty (manual brakes) on my 1972 C-10 and the brake light stays on on the dash now, any thoughts.
1970 SILVER CORVETTE COUPE AUTO 1971 SILVER CORVETTE COUPE 4 SPEED 1972 RED C-10 STEPSIDE 3 SPEED 1985 WHITE S-10 BLAZER AUTO 1998 WHITE S-10 4WD PICKUP AUTO 2006 SILVER H-D DYNA LOW RIDER |
01-28-2007, 10:43 AM | #2 |
its all about the +6 inches
Re: Brake Light
time to bleed the brakes. Maybe you'll see whwew all the brake fluid is draining out too.
01-28-2007, 07:07 PM | #3 |
Re: Brake Light
Could be MC push rod is knocking your brake light switch out of position while rebounding when brake is released. I've had same trouble on my 80 GMC, and have been totally unable to resolve problem yet. Tried a new MC seemed to help a little, but still have same problem, Duct taped the switch cures the problem, but is not ultimate cure. Marvxyz
01-28-2007, 08:35 PM | #4 |
Re: Brake Light
double check that the prop valve isnt tripped to one side. Check that the brakes work front and back.
01-28-2007, 08:53 PM | #5 |
Re: Brake Light
if one side of the master cylinder was almost empty, then the switch is doing the job it is intended to do.
