Old 12-31-2006, 08:59 PM   #1
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
WTB Trailing Arms
I need a good set of trailing arms for my 69 LWB that i'm baggin'. Not to worried about bushings because i plan to put new in.
IvelDesigns is offline   Reply With Quote
Old 12-31-2006, 09:18 PM   #2
67sss
67sss's Avatar
Re: WTB Trailing Arms
i have a pair, but do you think they can be shipped ups??
67sss is offline   Reply With Quote
Old 12-31-2006, 09:45 PM   #3
IvelDesigns
pm sent
Old 01-01-2007, 12:20 AM   #4
BarryB
BarryB's Avatar
If it doesn't work for the last guy I have a set also.
BarryB is offline   Reply With Quote
Old 01-01-2007, 12:51 AM   #5
IvelDesigns
the set he has in the pic are from a swb, but he is going to look for a lwb set tomorrow.
Old 01-01-2007, 01:23 AM   #6
Bob Moore
Not to mess up the sale but just to inform, I didn't think there was a difference between SWB and LWB trailing arms. I do know there is a difference between 1/2T and 3/4T arms but not SWB or LWB.
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 01-01-2007, 01:33 AM   #7
IvelDesigns
bob, thanks for the info.
that brings up another question though. my truck was a 3/4 ton, but the PO converted it to 1/2 ton and did disk brakes up front and 5 lug wheels all the way around. I have no idea what he used for a doner truck, but how can i tell for sure that he converted to 1/2 ton trailing arms?
Old 01-01-2007, 01:55 AM   #8
JDL
JDL's Avatar
I sure you could get a pair down here when you get to come down.
72 Chevy short step side with 454 air and tilt.
72 nova project car
63 chevy II drag car
Agency Iowa
JDL is offline   Reply With Quote
Old 01-01-2007, 09:48 AM   #9
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
From what I understand 3/4 & 1/2 ton trailing arms are the same with exception given to reinforcing the 3/4 ton units.
Can we get some 3/4 ton owners to post some pictures?
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 01-01-2007, 10:15 AM   #10
Bob Moore
I believe ECE sells(as probably do other board vendors) reinforcement kits. Look at their catalog to see what they look like. Basically they are a piece of 1/8th(approx) plate spot welded along the top and bottom of the arms. They are about 15" long and are at the back of the arms. It looks like they add strength by tying the 2 halves together.
Hope this helps - Bob
vac, 454, T400
more to follow
Old 01-29-2007, 07:30 AM   #11
shaneo2112RUSH
Junior Member
shaneo2112RUSH's Avatar
im looking for a good set of trailing arms pm me if anyone has a good set. mine are rusted and some of the rivots are missing
shaneo2112RUSH is offline   Reply With Quote
Old 01-29-2007, 09:50 AM   #12
rlm316
rlm316's Avatar
I have a c-20 and has the support flatstock tacked on the top and bottom at the spring area. If anyone has a good set I need them also and I will take either 1/2 or 3/4t. Thanks.
rlm316 is offline   Reply With Quote
Old 01-29-2007, 10:15 AM   #13
Joe Gribben
Joe Gribben's Avatar
if any one needs a set i have a clean set off a 1/2 ton sub?
Joe Gribben is offline   Reply With Quote
