Old 01-31-2007, 02:10 AM   #1
MisterE72
Keep Your Nose Clean
Rear as tank conversion...OK for lowered truck?
I recently went to the Turlock Swap Meet to buy a new rear gas tank conversion kit (72 blazer tank) for my 72 c10. Between the time the guy went to get the tank from the trailer and got back, some other guy convinced me those tanks hang too low for lowered trucks..and it would scrape. I did not buy it. So I ask the experts here today: Will the 72 blazer tank scrape if the truck is lowered 6" and riding on 20's with about 3" sidewall tires. I appreciate any feedback.
MisterE72 is offline   Reply With Quote
Old 01-31-2007, 05:18 AM   #2
GREASEMONKEY72
GREASEMONKEY72's Avatar
Re: Rear as tank conversion...OK for lowered truck?
to me it doesnt sound like it will but then i dont know how tall the blazer tank is but even then i dont think it will but it might in driveways and speed bumps and other things of the nature
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 01-31-2007, 05:59 AM   #3
brak
brak's Avatar
how low is your truck and what type of drop?
Blazer tanks hang low enough that you can see it when looking at the back of the truck, but if you are using a static drop i don't think you can go low enough to cause any harm. I would assume you would run into problems running airbags, definatley if you are trying to lay frame.
There are more than a few people with blazer tanks here, and i'm sure they will chime in soon
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 01-31-2007, 08:37 AM   #4
6772KEVIN
Junior Member
I had a blazer tank under the bed of my 72 long bed. It was lowered 7" in the back with no problems at all. Drove the truck everyday for 3 years.
6772KEVIN is offline   Reply With Quote
Old 01-31-2007, 09:50 AM   #5
65-72 chevytoys
65-72 chevytoys's Avatar
You could have a problem if you use bags and a C notch, otherwise drip springs will not cause it to bottom.
2004 Chevy Silverado 1500LS SWB 5.3L
2004 Corvette Z16 #770
Wish I had not sold 72 blazer
65-72 chevytoys is offline   Reply With Quote
Old 01-31-2007, 11:29 AM   #6
Hart_Rod
Hart_Rod's Avatar
What size is the tank? I've got bags, 2 inch lowering blocks and a c-notch in the back of my 69 Burb and my tank doesn't drag.
Hart_Rod is offline   Reply With Quote
Old 01-31-2007, 02:31 PM   #7
JameslovesJammie
God Bless Mr. T
JameslovesJammie's Avatar
That is a sweet burb!
Like a midget at a urinal...sometimes you must stay on your toes.
JameslovesJammie is offline   Reply With Quote
Old 01-31-2007, 02:44 PM   #8
jimmydean
jimmydean's Avatar
I have never heard anyone say a rear tank would rub. If it was a 25 or so gallon tank, it should be fine.
My air tank hangs down about 5" below the frame:
I have about 8" before my drain hits.
jimmydean is offline   Reply With Quote
Old 01-31-2007, 11:48 PM   #9
MisterE72
Thanks for the feedback. My truck will only have a 6"drop (5 "coil/1"block) and a c-notch. From the looks of some of the pics you folks sent, it should not hit. Thanks again. MisterE
