Old 06-07-2006, 06:47 PM   #1
stepside66
stepside66's Avatar
Question on my 62
hey guys I have a 62 SB fleet side that originally had a straight 6 in it and I took my 283/400 combo out of my 66. Since I am going to put it in there the question is what do I need to do to bolt it up to the frame I have the motor mounts from my 66 and the front clip is going on this truck also and It looks like I will need to do something with the radiator up front I have that from the 66 as well. here is a pic of what I have
stepside66 is offline   Reply With Quote
Old 06-07-2006, 07:50 PM   #2
bpmcgee
bpmcgee's Avatar
Re: Question on my 66
Step,
There's 3 holes in a line in the center of your front crossmember. That's where the original 283 would have fastened -- held in place by a U shaped bracket that mounts there, and to the face of the engine. If your engine isn't drilled for this, I understand there's also a way of making normal side-mount motor mounts work as well.
The radiator is a long way from the front of the short 283, so these trucks use a fan shroud about 6 inches deep to fill the gap. Of course, if you're not concerned about stock, ditch the mechanical fan and you have a TON of room for a couple of electric fans.
Brian
bpmcgee is offline   Reply With Quote
Old 06-07-2006, 07:59 PM   #3
stepside66
stepside66's Avatar
OK but I was planning on using the stock mounts on the sides like that are in the frame in the pic and using the mounts to bolt into the side of the block. I need to figure out how to mount the tranny on my crossmember the other truck was torched out and had a piece welded in there I dont want to do that is there somethig I can bolt into the cross member and then adapt on to the 400? and I think I will have to make a front crossmember to bolt the radiator in because my 66 had a place to sit the radiator in like two grooves
Old 06-08-2006, 01:12 AM   #4
bpmcgee
bpmcgee's Avatar
I think V8 motor mounts from a later (64-66) truck would work on that crossmember.
Brian
Old 06-08-2006, 09:33 AM   #5
stepside66
stepside66's Avatar
thats kinda what I figured but my main concern is the tranny mount.
Old 06-08-2006, 10:21 AM   #6
60-66 Nut
Professional Beer Tester
You can drill the holes and bolt the 66 frame brackets where you need them easy enough, but I don't think you will find any easy way to mount the 400 trans to the old bell housing crossmember. That crossmember may even be in the way and have to be trimmed or even cut out like your 66, depending on where you position the engine and transmission. If you can move the engine far enough forward, exaust manifolds and oil pan allowing, you might be able to make a bracket to bolt or weld to the torsion bar crossmember to mount the trans to. Hard to say for sure without seeing it all up close, but the 400 is a big trans and it takes up quite a bit of room.
60-66 Nut
60 Ford F100 Custom Cab
61 Apache Short Fleetside
64 C10 Short Stepside
65 C80 409 V8 5spd(X-Firetruck)
83 GMC 350 Olds Diesel
85 GMC Short Bed
86 GMC Short Bed
90 GMC R3500 Crew Cab
92 GMC 1500
60-66 Nut is offline   Reply With Quote
Old 06-08-2006, 12:41 PM   #7
JRB
JRB's Avatar
Aren't the frame rails wider on the 62? If they are can you adapt the front clip from the 66 to the 62? I had a 60 parts truck and found that to be the case but Im not sure about the 62. As far as the tranny goes I would cut out the old cross member and buy an aftermarket replacement.
Good Luck,
JRB
JRB is offline   Reply With Quote
Old 06-08-2006, 01:10 PM   #8
60-66 Nut
The 60-62 frame rails are wider at the rear, but they are the same width where the engine mounts go. I think maybe the crossmember that the torsion bars attach to might be in the way of an aftermarket crossmember, but I'm not sure.
60-66 Nut
85 GMC Short Bed
86 GMC Short Bed
92 GMC 1500
Old 06-08-2006, 05:37 PM   #9
stepside66
stepside66's Avatar
I sold my 66 without the motor and tranny for more than I paid for my 62 my 66 was on a 62 frame I found out. I wish I could get a 63 - 66 frame and yeah the torsion bars do mount into the tranny crossmember. Im not worried about the bellhousing mount just the one behind that where the bars mount to it.
Old 06-10-2006, 05:45 PM   #10
stepside66
stepside66's Avatar
Does anyone have anymore info on this swap that I could use
Old 07-07-2006, 06:52 PM   #11
chevytrucknut
chevytrucknut's Avatar
I put my '65 on a '62 frame. I had to make a crossmember for the radiator out of simple 2x3 steel tubing and the stock lower brackets. The 63-66 side mounts worked great just bolted them onto the engine then set it all in the frame.I also used a after market tranny crossmember. I set the engine forward 2 inches to allow more room for the HEI.
'77 GMC SWB
'66 SNB (Project)
Battle Ground, WA
chevytrucknut is offline   Reply With Quote
Old 01-28-2007, 10:58 PM   #12
stepside66
stepside66's Avatar
ah so you removed the torsion bar setup ??
Old 01-29-2007, 10:46 AM   #13
62ChevyStep
62ChevyStep's Avatar
I like many others here have done this swap. I used an 86' C10 front crossmember, A arms, spindles etc. took it to 5 lug, but much easier to find the suspension parts I need when upgrading/rebuilding. just my .02 worth
________________________
62' 3.5/5 drop SWB Fleet, PS, PB-Dsk/Drm,350/700R4
08' Chevrolet Silverado CrewCab
05'Toyota Tacoma Prerunner SR5
62ChevyStep is offline   Reply With Quote
Old 01-29-2007, 02:27 PM   #14
stepside66
stepside66's Avatar
thats what I plan on doing buddy of mine has a plasma so it will take just a fe min to get them loose and a buddy had a front crossmember he is giving to me so I will be pretty far ahead of where Im at right now
Old 01-31-2007, 11:21 PM   #15
Chevyboy1962
C10 now is a GMC
Chevyboy1962's Avatar
I did this swap on my '62 (V8 & auto trans) with the torsion bar setup.
I'm running a set of side mounts from a '69 C10 V8 mounts. If you're going with (side mount) engine mounts, I highly recommend(sp) using newer '73-'83 C10 engine mounts. These will have the "pin" setup, and makes it alot easier to change out engine mounts when they go. The pin goes in longways, and alot less cussing, and swearing. Ask me how I know.
I did have to cut out the bellhousing crossmember to allow the auto trans to go in. I did bolt up the engine mounts loosely to the engine, and lowered it into place. I marked the holes, pulled engine & trans back out, drilled holes, and reinstalled them. As for the trans crossmember, if keeping the torsion bar setup, you will have to fabricate a trans crossmember from scratch.
If you decided that you want to run disc brakes, and power steering, I highly recommend swapping out the front suspension FIRST before trying to install the engine. This way you can use a '63+ C10 automatic trans crossmember without it interfering with the torsion bars.
On the radiator setup, please use a 4 core radiator setup from the '63-'66 GM trucks. If you use the stock '60-'62 radiator, it will get the engine hot quick. I know mine did, and I swapped it out shortly after the engine was broke in.
If you don't have the radiator crossmember, you will have to fabricate one.
I'm using a '63 GMC 4 core radiator out of a '63 suburban that was recored, works great!!
I to fabricate one from scratch, I purchased a set of those "C" looking braces from one of the truck suppliers here on the board. I then welded the set onto a piece of 1 1/14' square tubing, with a flat piece of steel on each end that bolted to the frame rails. I then had the base of the radiator supported, then I just had to find a stock upper radiator support bracket off of a '63-'66 V8 truck.
I'm also running a set of hugger headers, these work great with torsion bars, but if the front is eqipt with a newer IFS, you will have a bigger selection of headers to choose from.
David
*1962 C10 swb fleetside, big window, custom cab 350/TH350 combo...Hot Rod
*1963 C10 lwb fleetside, small window 230/4 speed...Blvd Cruiser
*1931 Ford 5 window coupe (soon to be Hot Rod)... Father & Son project
Chevyboy1962 is offline   Reply With Quote
Old 02-02-2007, 08:43 PM   #16
stepside66
stepside66's Avatar
yeah I was at the local swap meet today and a guy has a complete rolling 63 chassis that he said he will sale me for 200 so thats what I will do and I am getting that front crossmember for free so I will change my tranny x member for a 700r4 mounted one from CPP and be done with that and I still have the radiator from my 66 I just have to fabricate the mounts
