Old 02-03-2007, 01:10 AM   #1
crm318
Alright Alright Alright
crm318's Avatar
white smoke on initial start up
i just started up a rebuilt 350 with vortec heads. as soon as i got it running, i reved it to 2000 reguardless of the timing. i tried to put it at the best timing to let it run. the exhaust was pumping out a slight white smoke that didnt smell like coolant and i didnt see any bubbles in radiator. the temp rose to about 195 and started to climb, which i assumed that the bad timing was the reason of the hot temp. the exhaust not sounded off to. tomorrow im going to start it back up, let it idle, and set the timing. what do yall think?
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 02-03-2007, 01:12 AM   #2
jhow66
jhow66's Avatar
Re: white smoke on initial start up
Normal. Run it awhile then see what it does.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 02-03-2007, 01:55 AM   #3
bigblockorange
could be water left in the exhaust. play with the timing quickly and finish braking in the cam it should be alright.
bigblockorange is offline   Reply With Quote
Old 02-03-2007, 08:54 AM   #4
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
Could've bent a valve from the wrong cam timing.
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily.
04 Pontiac GTO
04 Ford Mustang GT
68 C20 LWB stripper truck
73 K5 Cheyenne
76 C20 Sierra Crew SRW
88 K20 Suburban
I'm not hammering on metal just to hammer, i'm creating a piece of art.
1BadSS is offline   Reply With Quote
Old 02-03-2007, 09:59 AM   #5
rage'nrat638
rage'nrat638's Avatar
what kind of rockers are on this engine? they should be self aligning rockers,
on vortec heads. just a FYI
theres a few limits on cam lift and spring seat pressure with stock vortec heads without mods.
the first two pictures show self aliging rockers the last one is a reg style rocker.
hope you get it worked out.. your pal mark
rage'nrat638 is offline   Reply With Quote
Old 02-03-2007, 01:16 PM   #6
crm318
crm318's Avatar
yea, im using the self aligned rockers. the cam is .440/.440 lift which is under the .450 limit
1972 Cheyenne
