Old 01-31-2007, 08:16 PM   #26
cameeks
Long Fleet Club
cameeks's Avatar
Re: wasnt able to get her started today
Originally Posted by RedZ71 View Post
well at this point im fairly sure i have a fuel delivery problem. pressure in the fuel line was quite high, that when i removed the line from the carb, fuel sprayed instead of dripped. also, when i did drip some fuel into the carb, she did finally start, but then immediately died as soon as the tiny bit of fuel in the carb was consumed.
Just to be on the safe side befor you put the carb back on check the fuel pressure and make sure you are not over 7 lbs.
Chris Meeks
'69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling.
Truck is now finished to the new owners design and running around.
I was shown some pictures of the finished product. At least it survived the junk yard.
FAQ Index by Krue Site Vendors Subscribe Here Forum Rules
cameeks is offline   Reply With Quote
Old 02-03-2007, 03:25 PM   #27
RedZ71
Junior Member
RedZ71's Avatar
welp i just picked up the carb kit, so im about to attempt my first rebuild!
Jonathan
2001 ECSB Silverado Z71
1971 LB C10 Custom
www.z71silverado.com
RedZ71 is offline   Reply With Quote
Old 02-03-2007, 05:22 PM   #28
RedZ71
Junior Member
RedZ71's Avatar
so far so good, i have it disassembled, and have started the cleaning processes. im gonna take a break and pick up some heavy rubber gloves, so i dont die of cancer in the garage
Jonathan
1971 LB C10 Custom
Old 02-03-2007, 06:02 PM   #29
watahyahknow
watahyahknow's Avatar
brake cleaner does a nice job of getting the grease of the carb i've heared about Qjets is that there are 1 or two screws on the top that you need to watch out for when tightening cause overtightining bends the top of the carb .
there some stories on the subject in old hot rod magazines..... allways a good idea to keep those old magazines stacked up for future reference
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 02-03-2007, 07:24 PM   #30
FarmTruk
In Memoriam...
FarmTruk's Avatar
Here's a neat link with pics, showing disassembly and rebuild of '67-'80 Q-Jet for Corvette. Don't know exactly what if any difference in 'vette and truck carbs are, but it may be of some use.
Feel free to substitute the word "C-10" for "Corvette" as you review the document
http://www.corvettefever.com/howto/53360/
'68 C10 SWB 307ci 2BBL
FarmTruk Pics Here
"You know, doing what is right is easy. The problem is knowing what is right."
FarmTruk is offline   Reply With Quote
Old 02-03-2007, 10:54 PM   #31
VetteVet
Msgt USAF Ret
VetteVet's Avatar
here is another good one for rebuilding Q-jets
http://www.4wheelnoffroad.com/qjet.html
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 02-03-2007, 10:59 PM   #32
RedZ71
Junior Member
RedZ71's Avatar
so far so good, the carb kit comes with a numbered exploded view, so following that i was able to get it all apart for cleaning.
by the numbers, this carb is a 1971, 49 state chevy carb.
added a few pics at to the bottom of my page showing a bit of my teardown.
http://www.dfwlp.org/~jhorne/pics/truck/index.html
Jonathan
1971 LB C10 Custom
Old 02-04-2007, 03:58 AM   #33
regal8r
check, double check and then recheck again both the float level and float drop before u put it all back together...thats all im gonna say...lol
regal8r is offline   Reply With Quote
Old 02-04-2007, 10:47 AM   #34
Boog
laying low
Boog's Avatar
I'm sure it will start and run much better after the rebuild. I'm not sure but it looks like the choke may be missing something. Does it work at all? If it's missing parts it may be wiser to buy an electric choke conversion than to try to find any missing parts and get them adjusted right. Jeg's or Summit should have the conversion kits and maybe even a local parts store.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
