Old 02-04-2007, 11:05 PM   #1
xtreme80
Wishin' I had more money!
xtreme80's Avatar
What rear end gearing do I have?
My truck is a 1980, came from the factory with a 350-4bbl/TH350. It's got a 12 bolt rear end, not sure if that's original though.
How would I find out what gears I have in the back?
xtreme80 is offline   Reply With Quote
Old 02-04-2007, 11:52 PM   #2
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
Re: What rear end gearing do I have?
look in the glove box it should still have a paper tag telling you if not beats me also i think it might be on the driver door
Srubydo1986 is offline   Reply With Quote
Old 02-05-2007, 06:00 PM   #3
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
If it is anything but standard it will be listed in the glove box in the RPO section, if it is standard, it is most likely 3.08. There is a stamping on the axle, but I don't have the codes to decifer them...
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 02-05-2007, 06:10 PM   #4
msgross
msgross's Avatar
I have the codes for the ring gear numbers but you have to take the cover off....
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 02-05-2007, 06:31 PM   #5
Captkaos
Captkaos's Avatar
If you get in that deep you can just read them off the ring gear and divide them to get the ratio.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 02-05-2007, 08:43 PM   #6
xtreme80
xtreme80's Avatar
I'll just look at the RPO sheet. I don't think the 12 bolt came on the truck from the factory, but I'll just assume that it did!
Old 02-05-2007, 10:42 PM   #7
Srubydo1986
The Crazy Machanic
from what i was told the 2500 2wd did have a 6 lug 12 bolts but i think it was in a later models not our years
Old 02-05-2007, 11:10 PM   #8
msgross
msgross's Avatar
my 68 4wd has 12 bolt with 3.73's
The Garage:
Old 02-06-2007, 12:00 AM   #9
Captkaos
Captkaos's Avatar
12bolts came factory on all 73-80's. 10bolts started showing up in 81 and 12bolts were gone by 82...
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 02-06-2007, 01:50 AM   #10
xtreme80
xtreme80's Avatar
Oh! Then I'll look at the RPO sheet tomorrow and find out! Thanks!
