NOT REALLY BANNED!
![]() Join Date: Jul 2004
Front Crossmember Removal? Pics? FAQ?
Anyone have any info on how to do this?
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily. 04 Pontiac GTO 04 Ford Mustang GT 68 C20 LWB stripper truck 73 K5 Cheyenne 76 C20 Sierra Crew SRW 88 K20 Suburban I'm not hammering on metal just to hammer, i'm creating a piece of art. |
Re: Front Crossmember Removal? Pics? FAQ?
Are you asking about the front crossmember or the suspension crossmember?
The front is 4 rivits - grind heads off and use a punch. The suspension if a little more complex. Unbolt shocks, disconnect brake lines, unbolt and disconnect pitman arm from center link, unbolt idler arm from frame, unbolt and remove engine towers. All this gets you ready to undo the final 7 bolts on each side. Three are up and down from the frame through the crossmember and 4 are sidways from the frame through the suspension brackets outside the frame.
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
