Old 01-28-2007, 06:13 PM   #26
PBFAB.COM
PBFAB.COM's Avatar
Re: Anyone have pics of their rear air bag setup?
Originally Posted by SlammedDime View Post
Rarely do I see guys setting up their bags so that their ride height will be at the bags design height.
That comment is very true, but I am sure you would agree that the bags designed ride height is one of the most critical points of setting up an air system that rides well.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 01-29-2007, 01:48 AM   #27
laidout
Active Member
laidout's Avatar
heres mine but i think im going to change it to 4 link
laidout is offline   Reply With Quote
Old 01-29-2007, 04:15 AM   #28
SlammedDime
SlammedDime's Avatar
Originally Posted by madiron View Post
i think they are slam bags with the internal stops im pretty sure firestones compress more than slams
I'm almost 100% sure those are Firestone's pictured. The pewter looking top, and the color of the rubber give it away, not to mention that slam bags have the rubber going over the side of the caps.
Matt
Admin @ AirRideTalk.com
Win FREE Viair compressors!
SlammedDime is offline   Reply With Quote
Old 01-31-2007, 11:49 AM   #29
GWEE
GWEE's Avatar
Originally Posted by abadsvt View Post
So are you lookin for ideas or more of how others have theres setup? Here is my setup which is a little different that you might be looking for but I am proud of my setup so i will post it anyways. So what kind of rear setup where you thinking about going? Trailing arms with bags? 4 link and bags? Anyways good luck with your project
man i love that setup
tyhink im goin to do something like it
1985 GMC ( future plan pro tour build for the wife )
Black 2013 GMC single cab 4/7 drop on 24'' Torque Thrust ST
rules
GWEE is offline   Reply With Quote
Old 02-05-2007, 04:14 AM   #30
Raguemoe
Junior Member
Raguemoe's Avatar
Pics of my set-up!
Raguemoe is offline   Reply With Quote
Old 02-05-2007, 09:37 AM   #31
jlaird
jlaird's Avatar
nice job man! I need to get myself a tube notcher.
What route did you take with your rear disk setup?
What tire size it that? and backspacing?
jlaird is offline   Reply With Quote
Old 02-05-2007, 11:45 AM   #32
Raguemoe
Junior Member
Raguemoe's Avatar
CPP crossdrilled brake set-up F/R . 22x10 w/285 tire and a 5" backspace. Thanks!
Old 07-11-2011, 06:22 PM   #33
crispo-71
Originally Posted by Slammed67 View Post
With bolt-in c-notch....
did u need a top braket for that setup...i know u need some on the front right??
crispo-71 is offline   Reply With Quote
Old 07-11-2011, 06:40 PM   #34
vin63
It's Better With Nitro
vin63's Avatar
Not necessary for the rear as Slammed67's photo illustrates. I run an upper mount on my rear air spring (photo below), so that I can route my air line under the frame rail. The front typically requires an upper mounting plate, which covers the upper coil spring pocket.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 07-12-2011, 12:40 PM   #35
crispo-71
ohh ok so its fine if u put it under that c notch braket.... another question, did u have 2 change your tracking arm also?
Old 07-13-2011, 12:14 PM   #36
vin63
vin63's Avatar
Are you referring to the trailing arm? If so, no. I do have an adjustable panhard bar since my ride height is considerably lower than stock.
Old 07-13-2011, 06:40 PM   #37
kieth
kieth's Avatar
I only wanted to be able to control my ride height so I went with 8" bags that can go up to 12" in height, I installed a top cage to make the install easy, and just bolted the air bag directly to the trailing arm and bolted it on. I inflate with a schrader valve and it works like a champ. Cost less than $200.00
http://kieth.smugmug.com/Trucks/66-G...5_pTfv9bn-A-LB
kieth is offline   Reply With Quote
