Old 02-06-2007, 12:57 AM   #1
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
Where are you running your air lines into the cab?
I'm having a hard time deciding what is the best way to get the air line into the cab for my air gauges. I am going to be running 2 dual needle gauges and one single needle gauge in my hand made bezel (made from a glove box door).
i really don't want add more holes to the firewall. and i don't want them in the floor where they may get kicked. Also, do i need to use bulkheads for these?
Same question, but for the wiring for the switch box.
IvelDesigns is offline   Reply With Quote
Old 02-06-2007, 01:09 AM   #2
PBFAB.COM
PBFAB.COM's Avatar
Re: Where are you running your air lines into the cab?
Have you thought about a digital air pressure gauge? I am not sure on how much they run, but I am pretty sure Dakota Digital has them with senders. It could be worth the money?
I run the wiring through the floor under the seat... through a grommet.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 02-06-2007, 02:37 AM   #3
jimmydean
jimmydean's Avatar
I used the stock front mounting holes for the bench seat. I had to drill new ones for my 60/40. I made a grommet an have the air lines running through one and the wires running through the other. Here is a setup on ebay for $113 that I thought about getting, I just might have to.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 02-06-2007, 09:44 AM   #4
jlaird
jlaird's Avatar
Does anybody have any experience with that digital gauge on ebay? That same setup with the gauge and 5 senders from dakota digital is about $315.00. So either the FBI one is junk or the dakota digital is way overpriced.
jlaird is offline   Reply With Quote
Old 02-06-2007, 11:21 AM   #5
jimmydean
jimmydean's Avatar
Could be both. I was rethinking my setup because to add a tank gauge (I don't have one now) will cost about the same price. But to have to find a mounting point, run wires in place of the lines I have now, and wire it all up would be more effort than I care to spend right now.
If anyone gets it, please let us know what you think.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 02-06-2007, 12:16 PM   #6
IvelDesigns
a digital gauge won't look right in my truck.
has anyone here run air lines into their cab for the gauges? If not, where are you mounting them??
Old 02-06-2007, 12:42 PM   #7
jimmydean
jimmydean's Avatar
I have 4 - 1/8" lines running to my 2 dual needle gauges.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 02-06-2007, 04:29 PM   #8
SlammedDime
SlammedDime's Avatar
1/8" Airlines don't take up more room than 18 gauge wire... 5 of them running into the cab isn't really a big deal, about the same as one 1/2" airline. I would just find a spot, drill a hole, install a grommet, and be done with it.
Matt
Admin @ AirRideTalk.com
Win FREE Viair compressors!
SlammedDime is offline   Reply With Quote
Old 02-06-2007, 05:56 PM   #9
jimmydean
jimmydean's Avatar
I was able to fit 2 lines in each of the seat mounting holes and still had grommet room. They are flat under the mat running along either side of the tunnel.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 02-06-2007, 07:02 PM   #10
IvelDesigns
any concerns with them getting crushed or rubbing on the floor and wearing a hole into the line?
Old 02-06-2007, 09:05 PM   #11
jimmydean
jimmydean's Avatar
I ran them where the hump meets the floor. I put a strip of duct tape to secure them to the floor and it's under the pad. So if you step on them, the pad takes the brunt of the force and you can't step on the corner very easy anyway. The 1/8 line isn't easy to smash, so I'm not the least bit worried. It's covered, secured, and somewhat protected. If a hole wears in it, I'll patch it with my duct tape cup holder
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 02-07-2007, 12:13 AM   #12
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
Mine are put through a hole I cut in the floor, it's an elongated oval. The lines are held in place with two part epoxy, keeping them still and free from running.
I will be rerunning them when I redo my system and my center console.
Don't overtighten the air gauge fittings (my buddy put mine on for me, a job I thought he could handle; well my right rear is off by ~35lbs.)
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 02-13-2007, 06:44 PM   #13
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
I'm just working this out right now. My plan is to bring them into the cab behind the seat, turn a 90 and run them down the channel under the door sill. I plan to run Arkon fitting (Arkoncorp.com) and use fittings that are threaded on one end and have a push-loc fitting on the other. The threaded male end will run through a hole drilled in the floor and the female end will thread onto the other side. Arkon has a great selection of fittings including swivels which I plan to use in a number of places to allow for easy adjustment of angles... Let me know what you think.
1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD)
1978 Chevy C/10 SWB
1970 Pontiac Lemans
C10-Driver is offline   Reply With Quote
Old 02-13-2007, 10:31 PM   #14
Shane
Shane's Avatar
i think you mean www.alkoncorp.com
Shane is offline   Reply With Quote
Old 02-14-2007, 01:22 AM   #15
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
Thanks Shane... You're right.
Anyone have any thoughts on using the male/female connectors to go throught the floor of the cab. I thought it would be better than using a grommet (better seal, etc.).
1978 Chevy C/10 SWB
1970 Pontiac Lemans
Old 02-14-2007, 02:13 AM   #16
IvelDesigns
using a bulkhead might be a cheaper way to go. that, and that's what they are designed for.
i like your idea of running them under the door sills, but i come back to the same question i asked earlier; are you concerned about crushing them? i would think you'd be more likely to crush them under the door sills.
At this point i am considering building a center console for my truck. If i do that, it solves this issue since i can just run them under the console.
Old 02-14-2007, 02:20 AM   #17
jimmydean
jimmydean's Avatar
Any time you have a fitting, you have a chance for leaks. I tried to use as few fittings as possible and my system only has one leak (and it's a valve, not a fitting). It's a good idea, but keep leaks in mind, they suck.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 02-14-2007, 09:35 PM   #18
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
If I was going to install a console, I'd probably do the same thing. The lines are quite small and should fit in the door sill without too mush trouble. I was also thinking of using some sort of wiring "channel" (not sure of the term) similar to what they use in newer style trucks. It is the plastic "tunnel" that fits it the sill channel and clips closed around the wiring. Thoughts???
Agreed... I'll keep this in mind any probably try to minimize the fittings wherever possible.
These forums are great... every time you think you've thought a project through, somebody helps you think of something that you forgot about (or didn't think about at all). Thanks to everyone for their input.
1978 Chevy C/10 SWB
1970 Pontiac Lemans
