Old 01-06-2007, 05:06 PM   #1
kyull67
kyull67's Avatar
Question Sway bar mounting ?
I just bought a front sway bar off a 1980 3/4 ton pickup. My question is, is it okay to mount the bar directly to the frame and not use the brackets for more ground clearance?
kyull67 is offline   Reply With Quote
Old 01-06-2007, 05:16 PM   #2
see ten
WTB this ad
see ten's Avatar
Re: Sway bar mounting ?
I've seen it done that way. I don't see a reason it wouldn't work.
see ten is offline   Reply With Quote
Old 01-06-2007, 05:47 PM   #3
cgoodwin
cgoodwin's Avatar
kyull76,
Do you plan on taking pics with your install? I'll have mine coming soon from Brothers Truck and it might help me with my install.
cgoodwin is offline   Reply With Quote
Old 01-06-2007, 05:58 PM   #4
kyull67
kyull67's Avatar
Yeah I'll post pictures, but if you look in the faq truck tech section there's a really good write up with pics in there.
Old 01-06-2007, 11:33 PM   #5
Brad
Out of the carpool lane.
Brad's Avatar
My truck is lowered 4" in front and it fits better bolted directly to the frame. I've had mine like this for 6 years or more and no problems doing it that way. On a stock height truck I think you'll find it fits better using the brackets.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 01-07-2007, 11:05 AM   #6
neonlarry
neonlarry's Avatar
General rule of thumb for mounting swaybars is you want the arms parallel to the ground.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 01-07-2007, 01:36 PM   #7
kyull67
kyull67's Avatar
Thanks guys.
Old 01-07-2007, 09:27 PM   #8
Bamm
Cowboy Fan for Life!!!!!!
Bamm's Avatar
You can also switch it up and mount the sway bar on the "inside" of the front brackets. I've seen a post where someone did this, I'll see if I can find a pic. I think that will give you the "parallel to the ground" mount that you want...........Jerry
1967 ShortBed Fleetside
3/4 Drop 350/700R4
Tilt wheel
18 x 8 Torque Thrust II's
Future mods: All new gauges & wood bed
My Zip is 23002
I ship UPS, USPS
Bamm is offline   Reply With Quote
Old 01-07-2007, 10:49 PM   #9
kyull67
kyull67's Avatar
I was thinking of that but didn't know if it would be better than bolting it directly to the frame. At least I know it should be parallel to the ground now.
Thanks.
Old 02-05-2007, 10:49 PM   #10
dmsteele92831
Any one have pics? I have a 1 1/4" bar off an 84 chevy and want to make sure I mount it correctly!
Where can I buy brackets if I need them, or is a junkyard the best place to find them?
1968 c10 Chevy
2005 Infiniti G35
2006 Subaru WRX STi
dmsteele92831 is offline   Reply With Quote
Old 02-06-2007, 02:30 AM   #11
gringoloco
A guy with a truck
gringoloco's Avatar
If you are mounting to the frame AND bagged, you will run into interference problems with the pitman arm and drag link. I had to use 'lowered' style brackets for clearance.
-Chris
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 02-06-2007, 02:36 AM   #12
FLEET72
FLEET72's Avatar
ECE
Lowered $19
Stock $49
Oscar
'72 Shortbed Fleetside
'95 Jimmy 4X4
'69 GMC Custom Camper
FLEET72 is offline   Reply With Quote
