Egine V.I.N.
Hey does anyone know how to decode this vin on my engine -> C4Z155756 then in bigger letters a couple of spaces beside it says VO327TMM <- I cannot find any good websites on the internet and im trying to figure out if my truck is #'s matching!
Re: Egine V.I.N.
Re: Egine V.I.N.
yeah i tried mortec but i couldnt find the right codei went on some other sites and nothing was coming up as a valid engine its a 350 and if its #'s matching a 1969 C-10
Re: Egine V.I.N.
I Can Tell You This: The Vo327tmm Is Flint, Michigan March 27th, 1974 350 Conv. Cab., 145 Hp With A 2 Bolt Main For A C-10 Or 1500, Or It's March 27th, 1980, 350 Conv. Cab With A Manual Lt9, 170 Hp With A 4 Bolt Main For A C-20-3500. So No, It Doesn't Match Your Truck. As For The Other Set Of Numbers, Where Did They Come From? Both The 1974 And The 1980 Have The "tmm" So You Will Have To Know If It Is A Two Or Four Bolt Main To Determine The Exact Year. But, It's Definatly After 1969. Hope This Helps, Good Luck!
![]() - 1972 350 ENGINE - MUNCIE SM 420 - 4.56 GEARS |
#5 | |
Will it run today?
Re: Egine V.I.N.
V = Flint (Engine plant) 03 = March 27 = 27th day of March TMM = One of the following TMM 1974 350 conv.cab 145 2 C-10 & 1500 TMM 1980 350 conv. cab, a/t, Cal M LT9 170 4 C-20 to 3500 Found the information here: http://www.nastyz28.com/sbchevy/sblock.html Good luck! David
Jaws, the 1971 Chevy Cheyenne Longbed. She's big, grey, and has an insatiable appetite! |
Re: Egine V.I.N.
Okay, Figured Out The Other Part. That Is A V I N Code Beside Your Suffix#. It Is A 1974 For Sure. The "z" In The Number Is Throwing Me Off. It May Very Well Be A Crate Engine. But It Is A 1974, 145 Hp, 2 Bolt Main, That They Put On The C-10 In 1974
Re: Egine V.I.N.
thanks but that kinda sucks that its a '74 with 145hp i was hoping more for the '80 but guess there had to be a catch for the truck being this clean
Travis
travis_moffatt@hotmail.com ![]() 1969 Chevrolet C-10 LWB, 350c.i., TH350, In Pieces. 1991 GMC Sonoma, IROCS s10 grill 1963 Ford Galaxie 351/C4 |
