Old 02-05-2007, 11:14 PM   #1
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
Final Tranny Swap ?'s
If I use this crossmember:
http://www.classicparts.com/prodinfo.asp?number=79-507
And a TH350 with a short (READ: 6") tailshaft, it'll work with my stock driveshaft, that was originally hooked up to my 3speed manual? I just want to make sure before I start buying things.
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily.
04 Pontiac GTO
04 Ford Mustang GT
68 C20 LWB stripper truck
73 K5 Cheyenne
76 C20 Sierra Crew SRW
88 K20 Suburban
I'm not hammering on metal just to hammer, i'm creating a piece of art.
1BadSS is offline   Reply With Quote
Old 02-05-2007, 11:43 PM   #2
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
Re: Final Tranny Swap ?'s
ttt
04 Pontiac GTO
04 Ford Mustang GT
73 K5 Cheyenne
88 K20 Suburban
Old 02-06-2007, 04:02 AM   #3
Americanrider
The location of the tranny cross has nothing to do with the length of your tranny tail-shaft, only the mount points on the frame. You may have to drill new hole to mount your new crossmember but what you should ask:
Is the Th350 with the 6" tail the same length as stock 3sp? Got a tape measure and both trannys handy?
Americanrider is offline   Reply With Quote
Old 02-07-2007, 11:06 PM   #4
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
No, don't have the tranny yet. I need to know the differences because I need to order the th350.
I'm not asking about the location of the crossmember, i'm asking about driveshaft issues.
04 Pontiac GTO
04 Ford Mustang GT
73 K5 Cheyenne
88 K20 Suburban
Old 02-08-2007, 12:34 PM   #5
gyjackson
Yes....I did the swap. It is no problem, you can use the 3 speed driveshaft with no mods. providing you get a short tail TH350 to put in it's place.
'72 Custom/10 SWB project... converting to 4WD
'67 Camaro rs convertible...waiting in line
'99 Ext. Cab Z-71 190000 miles on orig. trans fluid
'02 Black Z-71 burb..(wife's)
'92 Accord (daughter's)....Who want's my insurance bill?
gyjackson is offline   Reply With Quote
