Old 02-10-2007, 10:36 AM   #1
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
rear main seal & torque specs.
I’m going to replace the main seal while the engine is out anyone have tricks to doing a leak proof job?
Also need some torque specs for the bolts.
Thanks.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 02-10-2007, 12:23 PM   #2
clay68c10
clay68c10's Avatar
Re: rear main seal & torque specs.
A tiny bit of silicone on the seal ends and on the main cap mating surfaces at the rear where the pan rubber sits. Also rotate the seal just a bit so it's parting seam doesn't match up with the main cap to block surface.
Someone out there has the torque spec handy....
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 02-10-2007, 12:59 PM   #3
kwmech
Main caps are usually 65 ft. pnds.
Old 02-10-2007, 01:05 PM   #4
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
I agree. Oil on the threads then tighten to 45 ft lb both bolt then 70 ft lb
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline   Reply With Quote
Old 02-10-2007, 02:12 PM   #5
Sport/Truck
Sierra Grande Club
Looks like I need to pull the oil pump too?? Should I get a new one from napa while I’m at it? Any special instructions to replacing the pump?
Thanks for answering my stupid questions; I’ve never done this before.
s/t
Old 02-10-2007, 02:21 PM   #6
rage'nrat638
rage'nrat638's Avatar
for the 35.00 cost i sure would and did. i love new stuff.
nothing like great oil pressure on your engine for piece of mind
rage'nrat638 is offline   Reply With Quote
Old 02-10-2007, 02:39 PM   #7
Sport/Truck
Sierra Grande Club
Do I need to prime this, or is that only needed on new motors?
Old 02-10-2007, 04:40 PM   #8
Sport/Truck
Sierra Grande Club
Got the main cap off and the seal was installed so that the ends of the seal were the same as the cap (not slightly off centered like it should be). Any way the one under the crank is easily moved seems like it’ll just come right out, but the one on the main cap is glued. Do I need to glue the new one on?
s/t
Old 02-10-2007, 07:39 PM   #9
kwmech
No reason to glue it, just make sure that the lip on the seal is pointing in the correct direction
Old 02-10-2007, 09:46 PM   #10
RACINJASON22
GEARHEAD
I agree seal will go in either way make sure seal lip is pointing toward the inside of the engine.
Old 02-11-2007, 12:58 PM   #11
Sport/Truck
Sierra Grande Club
Do the two ends need any sealant or will they just seal when it’s tightened up?
Old 02-11-2007, 01:12 PM   #12
clay68c10
clay68c10's Avatar
I've done it with just a miro-spot on the seal ends and without; it didn't seem to make any difference either way.
13 Tahoe LTZ
