02-10-2007, 07:03 PM | #1 |
Speedometer cable lubrication
What do you use to lubricate the speedometer cable?
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
02-10-2007, 07:12 PM | #2 |
Re: Speedometer cable lubrication
speedometer cable lube/ sold in auto parts stores is a dry graphite based product// you need to take the inner cable out of the housing then spray wd-40 down thru the housing to clean out crap then as you install the cable in the housing coat it with the cable lube
02-10-2007, 07:36 PM | #3 |
I pull the assy apart and flush out the housing with carb cleaner and brake clean Then I lube the cable with anti-seize.
