Old 11-15-2002, 10:19 PM   #1
love it loud
Calibration Engineer
love it loud's Avatar
73-87 control arm bushings
Hey, anybody know how to get out the old control arm bushings from 73-87 control arms? Got new energy suspension polyurethane ones to put in but no too sure how to get the old ones out without destroying the control arm. Is this possible or should I just leave it to a professional shop? Thanks for any input.
love it loud is offline   Reply With Quote
Old 11-16-2002, 12:41 AM   #2
Fast68Chevy
Fast68Chevy's Avatar
a little heat is a good thing, at least youre not having to do rear arm bushings, always have to completely burn them out, sometimes with leaf bushings also.,
Fast68Chevy is offline   Reply With Quote
Old 11-16-2002, 09:55 AM   #3
CustomChevy
A-arms
Assuming that you have the a-arms off of the truck, you can attempt to burn out some of the rubber from the old bushings. If you have a bench and a vise, you can vise a socket (can't remember the size, maybe 1" ?) and line it up with the bushing and proceed to hammer the a-arm down. This does work, but you have to be careful with the bushing housing for obvious reasons.
Overall, it's best to just have a shop take em out and press the new ones in, that way no problems with the arms.
That's my .02 worth. good luck!
CustomChevy is offline   Reply With Quote
Old 11-16-2002, 10:20 AM   #4
crazy longhorn
Fabricate till you "puke"
I have always burned the rubber, & pushed it out, then cut the shell in 2 places with my trusty torch. the shell pretty much fall out after it cools. after you clean up the holes with some emery cloth(not too much), you can press the new pcs in with a bench vise using the large socket method........carefull not to bend the arm.......
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 11-16-2002, 03:01 PM   #5
swervin ervin
You get what you pay for
swervin ervin's Avatar
When I did mine, I used a hammer and chisel to get them started, then used an air chisel to get the the rest of the way. It's a tough job, but it's not real bad with a air chisel.
Rebuilding the front end
Good luck with it.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 11-17-2002, 09:42 AM   #6
HeavyK20
HeavyK20's Avatar
Are 73-87 control arm bushings different than 71 & 72? I just took apart a 71 and I don't see any rubber in it. It actually looks like the threads of the bushing are the bearing surface. If this is the case, would I be better off upgrading to a 73-87 front. Are the 73-87 fronts a bolt in assembly for 67-72's?
Eric
1969 K20, 465/205 package
HeavyK20 is offline   Reply With Quote
Old 11-17-2002, 10:16 AM   #7
crazy longhorn
in 73 the 1/2 tons went to rubber bushings in the a arms. The 3/4 tons kept the steel bushings that all of the 67-72s had(through the 70s anyway). somewhere in the 80s, the 3/4tons also went to the rubber bushings......but Im not sure on the yr. Personally, I prefer the old steel bushings.......they ride a little harsher, but if they are kept greased they will last d@mn near forever
Old 11-17-2002, 11:10 AM   #8
HeavyK20
HeavyK20's Avatar
Thanks for the info, I think I am going to stick with the steel bushings also since I have everything.
How do I check for wear on the steel bushings?
Eric
Old 11-17-2002, 11:25 AM   #9
crazy longhorn
If the bushings are tight, you shouldnt feel an side to side "wiggle" in the a arms. The down side is that when the bushings wear, the shaft does also & you will be replacing shaft assemblys to get that good tight front end. I have in a pinch , replaced just a couple bushings, & it will work if the wear is minimal, but as a rule its a short lived fix. Good luck
Old 11-17-2002, 02:06 PM   #10
Brad
Out of the carpool lane.
Brad's Avatar
Yes! Follow Crazy Longhorn's advice-if you do stick with the stock bushings, replace the shaft as well. I didn't and thought I'd save some $$ and within 6 months I was replacing them again. After that I decided to go to rubber-well, I also wanted disk brakes so it was convenient.
Brad is offline   Reply With Quote
