Old 02-10-2007, 10:42 PM   #1
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Question Distributor Position
If the distributor is installed 180 degrees out will the engine still run?
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 02-10-2007, 10:49 PM   #2
rage'nrat638
rage'nrat638's Avatar
Thumbs up Re: Distributor Position
more popping than anything else
heres every thing you need to know
http://67-72chevytrucks.com/vboard/s...d.php?t=225820
rage'nrat638 is offline   Reply With Quote
Old 02-11-2007, 09:21 AM   #3
krue
Designated A-hole!
krue's Avatar
It will run perfectly....if you wire it 180 degrees out.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 02-11-2007, 09:32 AM   #4
kenm78
Broken Down
kenm78's Avatar
You can just pull you cap and plug wires off and start your firing order from where your Rotor is sitting and just adjust your distributor by twisting it. That is if you do not want to pull it again.. Just my .02
kenm78
1982 Chevy 4X4
Project truck
“It’s better to keep your mouth shut and let people wonder about your ignorance, than open your mouth and reveal all doubt”
kenm78 is offline   Reply With Quote
Old 02-11-2007, 07:53 PM   #5
crazy longhorn
Fabricate till you "puke"
180 out on the old points distibs.....a quick "git er done" , was cut the square peg off the rotor & turn it 180. square pegs dont fit round holes too easy(not without some screamin anywho ) Hell, if you set that #1 piston tdc (compression stroke), you can dump that dist in any damn way you like......just start # wire where the rotor is pointed(allready mentioned above)....... L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-11-2007, 08:21 PM   #6
slomotion
Old Duffer
slomotion's Avatar
It's not just the dizzy. You are better off to just roll the eng to #1 TDC, turn your dizzy shaft a little past where the rotor would match up with the cap's #1 wire, then lower it into the block and be sure it seats completely flush with the block. Don't forget that the dizzy shaft drives the oil pump! It will only seat correctly or 180 out.
'68 Short C20 Flatbed Dually
w/ 292 4bbl, Langdon cast headers,
and WC T5 trans.
'81 G10 Shorty Van
"Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers
"Under promise, then over achieve."
slomotion is offline   Reply With Quote
Old 02-11-2007, 08:26 PM   #7
msgross
msgross's Avatar
or in Australia!
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 02-11-2007, 08:30 PM   #8
rage'nrat638
that would be a little behind where it would line up with #1 on the cap
installing it spin's forward, removing and it spin's backward
Old 02-11-2007, 08:37 PM   #9
slomotion
Old Duffer
slomotion's Avatar
Thasright! Just DO incorporate the oil pump!
and WC T5 trans.
'81 G10 Shorty Van
