Old 02-12-2007, 07:42 PM   #26
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
Re: sb drivers side alt bracket upper
Originally Posted by jimmydean View Post
I didn't like my alternator hanging that far out, so I used a Camaro mount for the passenger side. It's a lot closer to the engine and doesn't look as bad IMO.
My truck is far from "correct" though.
That's why I have kept the later style pass. side mouinting the PO put on:
But recently, I've had this itch to get the engine bay looking more "stock".
Something about the primitive look of the older brackets looks cool.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 02-12-2007, 07:47 PM   #27
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Originally Posted by oldgold70c10 View Post
OK, here are some pictures I took of some brackets I am cleaning up to repaint.
The first pic shows a 67-68 bracket on the left and I believe a 69-71 on the right. The second pic is just the sickle-shaped part to compare the shape.
Thanks for posting the pictures; I assumed the 72 was the same also. Is this incorrect?
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 02-12-2007, 07:51 PM   #28
Sport/Truck
Sierra Grande Club
is that on a short WP?
Old 02-12-2007, 07:58 PM   #29
oldgold70c10
Who's got steelies?
From what I've read on this thread, the 72 bracket (just the sickle part) is a little different because the 72 alternator case was slightly larger. However, I haven't seen a 69-71 and 72 bracket side by side to tell you for sure
Yes, it is a short water pump. Passenger side bracket looks like it came off of a mid 70's Chevelle or Monte. Alternator is very close to fan shroud with this set up, but it uses a shorter belt.
My Truck Page
My Youtube Channel
Old 02-13-2007, 12:18 AM   #30
FarmTruk
In Memoriam...
FarmTruk's Avatar
I love posting pics. Here's mine on a '68 307.
Notice how close the Upper Radiator hose is to the alternator's cooling blades. It has actually "clearanced" the hose a bit, taking a small chunck out of the hose. Guess someone didn't have the right lenght belt last time it was replaced
I definately need to replace that hose and belt...
'68 C10 SWB 307ci 2BBL
FarmTruk Pics Here
"You know, doing what is right is easy. The problem is knowing what is right."
FarmTruk is offline   Reply With Quote
Old 02-13-2007, 10:29 AM   #31
craftsworker
Originally Posted by WorkinLonghorn View Post
I'm looking at the catalogue for www.truckandcarshop.com otherwise known as "Truck Shop" and they show the upper straight arm piece for $8.00. "O.E." type is $14.(?)
thanks for the link ...i took a look and though hard to tell from the pics on that site i believe the radius is incorrect,just like the universals.
'69cst/10
craftsworker is offline   Reply With Quote
