Registered Mail
Photos of your Floor Shifters!
I joust bought a borg-w 4 speed for my truck, its got a nice hurst shifter, but i don't know if the bench will be in the way, the handle is not that long, it was in a '80 camaro.. perhaps it won't reach.
I wanna see how long of shifters you guys use, perhaps i may need a new one..?
'67 chev 496, lwb to swb, bagged - pro street project |
![]() Join Date: Jan 2000
Re: Photos of your Floor Shifters!
I had a 3 speed floor shifter with the Hurst 4331 shifter handle. 6 cylinder mounting position. The handle just cleared the bench.
The 6900 handle is 3 inches shorter. Now that I have the Tremec TKO 5 speed, the 6900 handle fits better because the shifter is on top of the transmission instead of on the side like the 3 speed. Below is a picture of the two. Sorry I don't have a picture of them installed on the truck with the 3 speed. |
Registered Mail
Thanks! that is an awesome photo and the info I needed, mine is the same as the shorter one, but has a side bend in it.. obviously it will be too short.
nice work.
~Rest In Peace~
you will need the competiton /plus shifter4 spd to make clearance over the bench http://www.jegs.com/webapp/wcs/store...49299_-1_10523
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
When I put a "His & Hers" Hurst shifter in my`71 Blazer I bought a taller shifter.I know back then Hurst had a couple pages of levers in various configurations.I had it to where I could rest my arm along my leg on the edge of my seat and the handle was right there where my hand was.That`s the one thing I always remember about that rig.I could get in a mud-pit,steer with my left and grab gears with my right.I got another lever for my transfer case.I cut the factory lever to below the floor and welded the Hurst lever.It came up just to the right of the tranny shifter.So,I could kick it in and out of 4wd and grab gears w/o reaching,so I could do 2wd powerslides,then throw it into 4wd and blast straight out of my slide.(why did I every sell that thing?)
67-72 Addict!
This angle is not very good but here's a pic of my B&M Megashifter. The truck version is a little taller than this and better for a bench though.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
Yes, The Hurst catalog still has 3 pages of shifter handles (I think pages 47-49 inclusive). You can look it up online out of the Hurst master catalog (dial-up connections be warned, the master catalog takes a long time to download).
Aluminum slot wheels rule...
ttt
