Active Member
1989 tilt column........will it fit in a 1978?
I have been doing projects on 67-72 trucks for a while now and had the opportunity to score a 1978 loaded Silverado 4x4 with 73K actual miles!! what a nice truck...anyway it doesn't have a tilt column and I have a chance to get a nice tilt out of an 89 suburban...will it fit? what mods do I have to do if not? Thanks for your advice in advance, since it's my first foray into this generation of chevy trucks!!
Jim |
ureckmefixit2@cox.net
Re: 1989 tilt column........will it fit in a 1978?
Just put it in
That's U RECK ME FIX it 2 74 Chevy Short Bed 355ci Sportsman II 64cc Angle Plug Crower Custom Grind .462in .486ex Dyno Test 422hp @ 5600 And it's got a Holley 3.73 Gears 12 Bolt 3.73 w/Posi 700R4 Going In I'm a Body Man So There! That's why it's not painted |
The One And Only !!!
Physically it will bolt right in, But I read a while back about a guy doing this type swap and the ignition and turn signal switch plugs were different on the later column, He ended up re-doing the harness plugs.
LMC breaks the switches 73/87. Just something to make sure of before you purchase.
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
Professional Grade
Also note that your truck has the wiper switch on the dash, and the headlight switch on the floor, while the 89 will have both on the signal light stalk. It can be done, but expect to change some wiring around...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
Active Member
Hmmm.........good points on the wiring. I wonder if the 89 also has intermittant wipers on it? I would imagine a guy would need to get the wiper motor to match though. this might be an interesting project.....or I can hold for an earlier model tilt
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Other than the above listed wiring issues, it will physically bolt in, especially if it came out of a burb.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
yeller
I would get an earlier model tilt for ease of installation...they are plentiful around here and on ebay.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
Yep, Picked up mine on ebay for $60 including shipping....
