Old 02-12-2007, 04:36 PM   #1
bigo181979
Junior Member
bigo181979's Avatar
What proportioning valve do I use????
Well I am doing the 88 6lug brake conversion withe the c20 control arm and so on.
I got a new master cylinder for a 71-72 with disks but my auto parts dosen't show a listing for the propotioning valve. Does any one have a part number or have any info that could help.
bigo181979 is offline   Reply With Quote
Old 02-12-2007, 04:46 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: What proportioning valve do I use????
I would run the factory drum/drum block to maintian the dash warning light, and then an adjustable prop valve (aftermarket) for the reat. This way you can fine tune it instead of guessing, or going off of some one elses's *good enough* homework. Simply installing taller tires in the rear can throw the proportioning way off.
Old 02-12-2007, 04:54 PM   #3
Here is one source
http://www.inlinetube.com/Prop%20Valves/VCT103.htm
Other than that quickly, the only place (new-stock) I have ever found a proportioning valve was the dealer.
Using an aftermarket adjustable is probably the best bet as Andy mentioned.
Old 02-12-2007, 11:20 PM   #4
bigo181979
Junior Member
bigo181979's Avatar
anyone else????
Old 02-13-2007, 02:37 AM   #5
pebbleboy
Son Of Gravel Man
pebbleboy's Avatar
gmcpauls.com
http://www.gmcpauls.com/Brakes&Steering.htm
Brake Proportioning Valve W/Bracket & Lines Each
1286368 New replacement brake proportioning valve with correct mounting bracket to mount the valve to master cylinder, proportioning valve to master cylinder pre-bent brake lines. All needed installation hardware is included. Specify in cart style needed. Disc/Drum, or 4 wheel disc brakes. $89.95
Did you lok at this one?
I used the disk/drum one when I did my drop/front disk conversion.
Daily driven 70 C10 longbed
Its a work in progress
Originally Posted by Longhorn Man
What one man calls a budget part, another man calls his entire budget.
pebbleboy is offline   Reply With Quote
Old 02-13-2007, 10:18 AM   #6
bigo181979
Junior Member
bigo181979's Avatar
Originally Posted by pebbleboy View Post
gmcpauls.com
Thanks thats what I was looking for.
Old 02-13-2007, 08:44 PM   #7
pebbleboy
Son Of Gravel Man
pebbleboy's Avatar
Glad i could help.
