02-12-2007, 09:27 PM | #1 |
454 temp sender
by chance, is it possible the temp sender for a 76 454 might be under the exhaust on #8 cylinder? I have a strange leak that I am finding it difficult to believe would be a head gasket. I have no reason to think the gasket went. When I either step on it hard or am trying to run above 60 mph it will blow antifreeze on the exhaust and I just haven't had time to get under the truck to look
02-12-2007, 09:38 PM | #2 |
ureckmefixit2@cox.net
Re: 454 temp sender
I think there is a plug between 1 and 3 exhost ports and 6 and 8. the sender is on the drivers side on mine. You might have a leak at the plug where the sender would be?
Matt
That's U RECK ME FIX it 2 74 Chevy Short Bed 355ci Sportsman II 64cc Angle Plug Crower Custom Grind .462in .486ex Dyno Test 422hp @ 5600 And it's got a Holley 3.73 Gears 12 Bolt 3.73 w/Posi 700R4 Going In I'm a Body Man So There! That's why it's not painted |
02-13-2007, 07:39 PM | #3 |
Re: 454 temp sender
The heads are identical left and right and as ureckme said, their is a plug between 6&8 that could be leaking. I have been told before by GM when I worked at a dealership to put the temp sender on the passinger side head.
'96 Nissan Pathfinder '02 Firebird Trans Am. '88 K5 Blazer |
02-14-2007, 10:00 AM | #4 |
Re: 454 temp sender
hmm every 454 ive seen had the sensor on the driver side head but i know on the pass side the knock sensor goes on that side and im havin problems with my dads 468 we put in we took a 95 gen V 454 out and had no knock sensor
http://img.photobucket.com/albums/v5...ropped/sig.jpg |
