Old 02-15-2007, 09:26 AM   #1
manimal
manimal's Avatar
Motor mount position
My truck was originally equipped with a 6 banger now has a 350. It sits very far back,do I need to move the motor mounts? there is only one hole in the bottom of the crossmember for the lower bolt,so I am unsure what I need to do to move it forward.Thanks.
-Lance
manimal is offline   Reply With Quote
Old 02-15-2007, 09:39 AM   #2
cooters
Re: Motor mount position
check out the faq section, there should be lots of info there
cooters is offline   Reply With Quote
Old 02-15-2007, 09:46 AM   #3
Ram-Man
Ram-Man's Avatar
This is where it should be. On a 1970 with a 350.
Ram-Man is offline   Reply With Quote
Old 02-15-2007, 10:01 AM   #4
brak
brak's Avatar
Check the classified section or post a WTB for a set of V8 towers, you should be able to find a set fairly cheap.
The V8 towers sit further forward, and are lower than the I6 towers, which would be necessary to maintain proper driveline angle. As you've probably noticed, the V8 on I6 mounts tilts rearward due to the wrong mount height, as you can see in the pic of my truck mounted that way
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 02-15-2007, 10:03 AM   #5
manimal
manimal's Avatar
I searched the FAQs and nothing.Are the 6 cylinder and Small V8 the same perches? I also have a 3spd manual trans and the bellhousing is bolted to a crossmember.Can I remove that crossmember and use a standard trans crossmember to move my engine foward?
Old 02-15-2007, 12:25 PM   #6
crazy longhorn
Fabricate till you "puke"
The I 6 & the sb V8 stands are different(you cant just move yours ahead). if you opt for the V8 stands, you will also need to remove the bell mount crossmember, & discard it. You can then use an auto trans crossmember under your 3 spd stick trans(the crossmember will be in the frame holes for 1 equipped with a 350 turbo. You will need to lenghten you driveshaft(you will be sliding the eng foward 3 1/2"), & you will also need to rework your clutch linkage, as well as adjusting the exhaust, & no doubt shift linkage.
Personally, I like to run my sb in I6 spot,& havent had any weird angle issues, or problems(other than the distrib is close to the firewall ). here are a few shots of mine..... http://community.webshots.com/user/hotrodhorn best of luck, L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-15-2007, 03:06 PM   #7
kaycee
kaycee's Avatar
Don't forget about your driveline if you move it forword it will be to short then you will have to spend $ to get it right.I have my sb in the back hole and no issues at all.
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
