Old 02-15-2007, 01:17 PM   #1
RedZ71
Junior Member
RedZ71's Avatar
disassembling a 71 bed
anything in particular that i need to watch for while i disassemble the bed i bought yesterday? i need to take some of these parts, and some of the parts on the one i already have on my truck, and build one bed.
any gotchas to watch for would be appreciated.
Jonathan
2001 ECSB Silverado Z71
1971 LB C10 Custom
www.z71silverado.com
RedZ71 is offline   Reply With Quote
Old 02-15-2007, 02:37 PM   #2
1971LT1SWBPOSI373
1971LT1SWBPOSI373's Avatar
Re: disassembling a 71 bed
ttt
1971 Shortbed 350/350 w/ Posi-traction 3:73's
1996 Chevy Silverado
TJ in Springfield, Virginia
Likes old Chevy trucks
Drinks Miller MGD
1971LT1SWBPOSI373 is offline   Reply With Quote
Old 02-15-2007, 05:01 PM   #3
skchevota
skchevota's Avatar
Soak the bolts with some wd-40 or simmilar before you start. If the bolts start to losen then get tight and strip the square part on top so they just spin, I use an impact in forward and just snap off the rest to avoid the trouble.
skchevota is offline   Reply With Quote
Old 02-15-2007, 06:50 PM   #4
BigTex
The biggest issue I had was the original bolts spinning in the square holes, just as skchevota said. I ended up using a cutoff disc on just about all of the bolts. I wish I had thought about the impact wrench, it would have made less mess.
Richard
1970 Chevy (growing pile of parts)
2003 Silverado SS
BigTex is offline   Reply With Quote
Old 02-15-2007, 06:51 PM   #5
BigTex
RedZ71 - are you sticking with the long bed or converting to a shorty?
Richard
2003 Silverado SS
Old 02-15-2007, 11:44 PM   #6
BCOWANWHEELS
use the impact and tighten them till they break off is the best. you dont reuse them anyway.
BCOWANWHEELS is offline   Reply With Quote
Old 02-16-2007, 08:47 AM   #7
RedZ71
Junior Member
RedZ71's Avatar
haha, oh ill be reusing them... since im taking 2 old beds and using their parts to make one useable bed.
im seeing a few places where it looks like a couple of welds might be holding pieces together, whereas i thought it was all just bolted. am i going to have to cut some welds off, and if so whats the best method for doing that (ie, considering i have no welder).
thanks for the replys yall!
Jonathan
1971 LB C10 Custom
Old 02-16-2007, 09:34 AM   #8
AKChevyman
Chevy Forever
AKChevyman's Avatar
Take a dremel tool with a small cut off wheel and cut the four welds they aren't very big and those are the only ones on the bed. Too bad about the welder I just spot welded the heads of my carriage bolts in place so they wouldn't spin. And look out for the 4 Phillip's screw's at the front you will either have to heat them up till the glow red to get them out or drill them out. Those have to be the dumbest idea ever since they are the same thread pattern as the bolts on the rest of the bed.
My first love
1971 C20
Hugger orange
Getting face lift and heart transplant .30 402 BB /TH400 and GV
Wifes car
1969 Chevelle SS 396 325hp/TH400
Factroy A/C Automatic w/ Floor shift console.
restored.
AKChevyman is offline   Reply With Quote
Old 02-16-2007, 10:58 AM   #9
Huck
Huck's Avatar
As mentioned, quickest and easiest method of removing panels is to tighten the small carriage bolts to snap them off as loosening them almost never works. You have a couple of welds where the C pillar attaches to the rear floor. You can cut them with a dremel, a grinder, a torch or use a air hammer chisle to separate them. You also have 4-6 bolts on those C pillars so check them out pretty good. On re-assemble, you need to get the bed square---and you also need to get the rear quarters perfect for the tailgate so take your time and square things pretty good. After assembly and assuming your tailgate is lined up and latching nice---you should re-weld those lower C pillars to keep things aligned. The plant used a jig for this.
Huck is offline   Reply With Quote
Old 02-16-2007, 12:00 PM   #10
northerngmc
northerngmc's Avatar
Can someone post a picture of these welds? I am trying to visualize them but can't seem to and my truck is sitting in the back yard under 1 1/2 feet of snow!
I am also hoping to take 2 or 3 long beds apart and use the best parts to make one for a driver.
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 02-16-2007, 01:23 PM   #11
timcos
Chief Honcho In Charge
timcos's Avatar
What is a C- pillar...first I have heard of that...
1992 1500 4x4 Shortbed
1984 Ford F250 Supercab Longbed 6.9L Diesel
1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
1967 C10 SWB (1980-1981)
1971 C10 LWB (1998-2004)
timcos is offline   Reply With Quote
