02-14-2007, 12:51 AM | #1 |
Wtb Nv4500
I need a trans for my truck looking for an NV4500 I will take a 2wd or 4wd. I needed every thing to put it in a GMC.
Earl 68 2500 4x4 GMC Burb |
02-14-2007, 12:11 PM | #2 |
Re: Wtb Nv4500
I'd like to have one too. Have you priced the adapter to bolt it to 205 or 221? It costs more than a tranny. I haven't been looking hard but I usually don't have too either. The adapter is in the 1500 range I believe.
69 Chevelle SS 375/396 TKO 600 71 Suburban 3/4 4x4 402 5-speed (project) 68 chevy C10 shortbed 327 5-speed (project) 72 Blazer 4x4 400 4-speed (wifes project) Numerous 67-72 parts trucks Last edited by Troy-Built; 02-14-2007 at 12:11 PM. |
02-14-2007, 08:54 PM | #3 |
Re: Wtb Nv4500
Get one from a dodge cummins, they are a nv4500HD, they cane with a np205 stock, and you can get a bell housing froM advanced adapters for like $500. Or use the chevy one and use a NP241, it has a way better low range is very srong and weighs half as much as a 205. or, use the chevy on and the dodge np205, change the input on the 205 to the chevy 32 spine unit and use a clocking ring so you can ajust where the tcase front output height is.
02-15-2007, 02:37 PM | #4 |
Re: Wtb Nv4500
OK looks like it's time for an nv4500 course . The nv4500 never came with a np205 behind it in any application{I wish it did},however the Dodge version will accept a Dodge 205 with no adapter. The GM version will accept a late 85-91 32spline np205 with a $103 spacer avaliable from Advance Adapters. There is no adapter for the 221 Rockwell. The adapter for the standard 10 and 27spline 205 is between $500-$650 from AA. We have put together various combos and currently are assembling a Cummins,GM NV4500 with Cummins input and a late 32spline GM 205. Another thing is there were a few short input 32spline GM 205's that will bolt directly to the back of the nv4500. However I have never seen one in person.
FYI, I'm in the parts business and deal in these parts regularly.
01 2500 Duramax,6spd,4x4,Not stock. Estimated 550rwhp/1100rwfp on fuel only. 03 3500 Duramax,6spd,4x4,Pac-Brake,not stock Estimated 500rwhp/1000rwfp fuel only 67 K10 in many pieces Little Brothers truck 67 K20 Cummins 12V/NV4500/205, D60/Eaton w/ Detroit,37" Xterrains,crossover steering, Future plans,Twins and lots of fuel. |
02-15-2007, 02:42 PM | #5 |
Re: Wtb Nv4500
I was hoping to find a 2wd trans and then just use a divorced transfer case. I have a 32 spline 205 but its the figure 8 style so I cant use the spacer but its cheaper to get the newer 205 then it is to get the adaptor from AA so if i get a 4wd trans then ill just find a newer 205 to use.
02-15-2007, 03:50 PM | #6 |
Re: Wtb Nv4500
Sorry to barge in, but does anyone have any hints for mating an 85 NP208 to an NV4500? I've heard/read that its a possible bolt on, but haven't been able to find the web pages where I read it, or to confirm it.
Currently the 208 is bolted to a 465 trans that looks to be an 85 as well. At least the shift rod is chrome and not shaped like the correct shifter for a 72 truck. I think... I've also not had much luck finding this info on the web. I'd like the later 4500 with a synchro first and about 5.6 first gear. Thanks Last edited by 72lb4x4; 02-16-2007 at 02:15 AM. |
02-15-2007, 06:57 PM | #7 |
Re: Wtb Nv4500
I would check advanced adaptors web site they have a good chart with all the chevy trancfer cases and witch kit is or is not needed.
02-15-2007, 07:10 PM | #8 |
Re: Wtb Nv4500
try this http://advanceadapters.dirxion.com/d...en=1024&os=win go to page 42 of thier catalog.
02-16-2007, 01:38 AM | #9 |
Re: Wtb Nv4500
i,ve got a chevy 4 wd nv4500 that is hurt inside for 200.00 plus shipping. also here is a good link for nv4500 trans.
bob in kingsport, tn. http://www.mantrans.com/ |
02-16-2007, 02:16 AM | #10 |
Re: Wtb Nv4500
BCOWANWHEELS,
looks like we live in the same town so shipping wouldnt be an issue do you have the bell housing every thing r just the trans?
02-16-2007, 09:27 PM | #11 |
Re: Wtb Nv4500
just the trans.
