Old 02-13-2007, 02:43 PM   #1
southern parts
southern parts's Avatar
71-72 gas pedals $15
71-72 Gas pedal $15 ea plus shipping
southern parts is offline   Reply With Quote
Old 02-15-2007, 06:48 AM   #2
Snohog
Junior Member
Snohog's Avatar
Re: 71-72 gas pedals $15
Can you check shipping to 64123. I would like to convert my 70 to this style pedal. Couple of questions, does this style use cable versus rod? Whats the difference in left one and right one?
68 SWB all over the garage
86 LWB silverado
2006 silverado SS
Snohog is offline   Reply With Quote
Old 02-15-2007, 07:18 AM   #3
southern parts
These do use cables. the one on the left can be used with a 400 trans, the kick down switch bolts into the square hole. I`ll check shipping for you this evening when I get back from work. Woody
Old 02-15-2007, 04:14 PM   #4
DoobieBrother
DoobieBrother's Avatar
I have a 68 with the older style pedal (bottom hooked to floor) and would like to switch to this kind. Do you know what all would be involved? Also, my truck has a 350 in it w/ a 3pd auto. Eventually, I will probably go 700R4 or similar. So, would the one on the left work for me or would I be up for a bunch of fabrication either way?
DoobieBrother is offline   Reply With Quote
Old 02-15-2007, 06:13 PM   #5
southern parts
snohog- Shipping will be $10.84
doobiebrother-Either one will work. Not a lot of fab work, drill four holes, three to mount the pedal, one for the cable (you will have to use a flat file or die grinder to square this hole for the cable to lock into)
I dont have the cables or bolts to mount the pedals.
Old 02-15-2007, 08:39 PM   #6
Snohog
Junior Member
Snohog's Avatar
I'll take the one on the right, looks to be in the best condition. Do you paypal?
86 LWB silverado
2006 silverado SS
Old 02-15-2007, 08:57 PM   #7
Snohog
Junior Member
Snohog's Avatar
Paypal for $25.84 sent, thanks.
86 LWB silverado
2006 silverado SS
Old 02-16-2007, 10:12 PM   #8
southern parts
snohog- your pedal is on its way. Thanks, Woody
