Old 02-18-2007, 12:32 AM   #1
stefan
New Member
rear 8 inch drop and notch
i was just wondering,i dropped my truck 8 inches in the rear and it has coil springs and the rearend is right at an inch from the frame,do you guys think a bolt in small notch will be enough or will it hit the frame alot,i just dont want to cut the bed,thanks for any help guys.
stefan is offline   Reply With Quote
Old 02-18-2007, 02:03 AM   #2
SCOTI
SCOTI's Avatar
Re: rear 8 inch drop and notch
Typical suspension movement is about 4": 2-up; 2-down. A bolt-in c-notch would work if you don't carry much of a load.
How did you arrive @ the 8" drop?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-18-2007, 02:36 PM   #3
stefan
New Member
used 6 inch springs from early classics and 2 inch blocks from classic performance and pinion shims from them also and just need a notch.
Old 02-20-2007, 06:36 PM   #4
smbrouss70
smbrouss70's Avatar
I have a similar set-up right now, just home-made blocks instead of manufactured ones. I installed the bolt-in c-notch and I don't believe it has ever bottomed out (of course, luggage and my dogs are the heaviest things my truck carries.)
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
