Junior Member
![]() Join Date: Jun 2003
front coil spring
When replacing the front coil spring should it completely cover the hole (drain) in the lower a-arm? I have an assembly manual and have not been able to locate this detail.
Dave's not here, man
Re: front coil spring
Does the lower control arm have a recessed area that the spring rides in?
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
The hole in the stock arm has a stop in it. The hole is shaped like the spring, if you turn the spring clockwise, it will turn until the end of the spring hits the stop. That is when it's fully seated.
I think that's what you're asking, right?
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
Junior Member
Thanks Jimmydean, thats exactly what I was asking. I thought the spring should be rotated up against the stop. I was questioning the covering of the hole because on other GM products the end of the coil is not supposed to completely cover this hole. Thanks for the replies.
