Old 02-21-2007, 06:24 PM   #1
magnethead
7000 #'s of american IRON
magnethead's Avatar
corp 14 vs D70 vs D70HD DRW?
does anybody know what RPO options had to be selected to get the different axles? I keep reading that dually's have regular corp 14 bolts, but my truck has a D70. Is the D70 specific to the camper special package?
and how can one tell the D70 and D70HD apart? I think mine's a 70 HD but the tag says rear axle rating: 7500, which is the rating for a 70.
magnethead is offline   Reply With Quote
Old 02-21-2007, 07:17 PM   #2
watahyahknow
watahyahknow's Avatar
Re: corp 14 vs D70 vs D70HD DRW?
im curious about that one too .....the hd version might have a posi
http://www.chuckschevytruckpages.com/14bolt.html found a little bit of info here you might want to look further on that site
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 02-21-2007, 08:57 PM   #3
magnethead
magnethead's Avatar
it looks to me like the D70 is a 3.562" axle tube and HD has a 4" tube....my truck has 4"ers.
http://www.pirate4x4.com/tech/billavista/D70/D70.htm
http://coloradok5.com/forums/archive.../t-134187.html
Here's off my truck:
Old 02-21-2007, 10:28 PM   #4
edman87
junk collector
I didn't know the camper special came with a d70, I thought just the cab and chassis came with the d70. Wasn't the reason for the difference the axle width? The d70 setup is 5-6 inches narrower, right?
'87/89/76 K5 in progress
'99 K2500 short crew
'91 camaro rs
'98 jeep tj
'52 willys cj3a
edman87 is offline   Reply With Quote
Old 02-23-2007, 02:16 PM   #5
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
If you pull some info off the axle, it will tell you all you need to know about it. Spicer has a good site with docs on identifying your axle. As for the RPO codes this site may help.
http://www.chuckschevytruckpages.com...s_1973-87.html
Twisted78SS is offline   Reply With Quote
Old 02-23-2007, 04:28 PM   #6
watahyahknow
http://www.700r4l60e.com/diff_ident.html
Old 02-23-2007, 08:17 PM   #7
magnethead
magnethead's Avatar
i got 4 foot between wheelhouses, std width for a dually.
Old 02-23-2007, 08:19 PM   #8
magnethead
magnethead's Avatar
that will help the most, as soon as i get the quarter inch of muck off the housing.
Old 02-23-2007, 08:30 PM   #9
magnethead
magnethead's Avatar
can you specify where? I couldn't find a single bit on dana.com.
Old 02-24-2007, 01:30 AM   #10
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
I think the HD D70 has a larger ring gear of 11.5 instead of the 10.5
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 02-24-2007, 05:14 AM   #11
watahyahknow
http://www.chuckschevytruckpages.com/14bolt.html this is the direct link fron chucks pages
HERE IS A CLOSE-UP OF A 14 BOLT GM REAR END. IT IS IN A 1977 CHEVY K/20. IT IS A FULL FLOATING AXLE, WITH THE MASSIVE 10 1/2" RING GEAR. THE AXLE SHAFTS ARE HELD IN WITH BOLTS.
THE SMALLER 14 BOLT, WITH IT'S 9 1/2" RING GEAR, IS A SEMI-FLOATING DESIGN. IT USES C-CLIPS TO HOLD THE AXLES HAFTS IN. JUST LIKE THE 10 BOLT, AND 12 BOLT GM REARS. THIS MEANS IF YOU SNAP AN AXLE SHAFT, YOU COULD LOSE A REAR WHEEL, IF YOU WERE TO DRIVE THE VEHICLE THAT WAY. SNAP AN AXLE WITH THE FULL FLOATING DESIGN, AND IT STAYS ON THE VEHICLE.
Old 02-24-2007, 08:08 PM   #12
magnethead
magnethead's Avatar
i got that, but what are the differences between the two D70's without popping the cover?
Old 02-24-2007, 08:37 PM   #13
watahyahknow
i dunno maibe its possible to see it at the type of hubs/drumbrakes that are on the axle the semifloating desighn as far as i know have the drum over the end ov the axle the full floater will have the axle in front of the drum and you can take it out without removing the weel (s)
i still have to delve deeper intoo that foir my own truck i want to rebuild it intoo a narrow track dually (wheels inboard of the fleetside bed )
