Old 02-20-2007, 01:58 AM   #26
jlaird
jlaird's Avatar
Re: impala rear disc???
So to sum things up, do certain rearends and/or axles need a specific bracket thickness? I'm kind of confused from this thread. If so, Glock, can you post what situations need what bracket thickness?
jlaird is offline   Reply With Quote
Old 02-20-2007, 10:07 AM   #27
383 Stroker
383 Stroker's Avatar
My Rearend is a 71. You need to radius the outside corners the same as the inside of the rotor. Plus you need to get the outside lip of the parking brake drum cut off on a brake lathe so that the rotor does not hit the backing plate on trucks that have a lot of axle walk. My caliper bracket bolt holes are 1/2 sae thread and you need to drill out the caliper bracket bolt holes a little for the 1/2" bolts to go through.
Video's of my Truck Racing
1967 C-10, 383ci Sbc, TH350, 3200 stall, 3.73 gear
383 Stroker is offline   Reply With Quote
Old 02-20-2007, 10:53 AM   #28
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Originally Posted by action View Post
I also bought the brackets from Glock ( Nice pieces) Anyway it will be a while untill I use them but it looks like just a little clearnceing (SP?) will do the trick.
I hope it all works out.
Jack
Jack,
Let me know if you have any issues when the time comes, and I will get you a new set.
Bob
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 02-20-2007, 01:09 PM   #29
manimal
manimal's Avatar
Couldn't you just mill the mounting area 3/16 and leave the bracket 3/8 thick? also for the mounting bolts couldn't you use button head allen bolts? Just a thought.
-Lance
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 02-20-2007, 01:12 PM   #30
manimal
manimal's Avatar
I would also be interested in a set of these brackets. How much are they?
-Lance
Old 02-20-2007, 01:16 PM   #31
glock35ipsc
Lance - They sell for $50 a set with hardware, which will include new/different bolts for the OEM bracket to fix that clearance issue. I still have some 3/8" brackets, and will have 3/16" brackets soon.
I might have to try that on a set, to mill the area that mounts to the flange down to 3/16".
Bob
Old 02-21-2007, 09:17 AM   #32
jkade
jkade's Avatar
I put mine on last night and the same thing happened with mine. I am going to try and go to the parts store today and see if I can come up with a bolt that will work. I am not mad at you Glock these kinda things happen and if they are going to happen it will always be to me. I will let you know what I come up with.
jkade is offline   Reply With Quote
Old 02-21-2007, 10:03 AM   #33
glock35ipsc
Thank you for understanding Kade. And like I said earlier, I will replace ANY and ALL of those that will not work with the new, thinner brackets. I do have the thinner ones in the process of being made as we speak, and hope to have them ready to go by the end of the week.
Bob
Old 02-21-2007, 12:21 PM   #34
jkade
jkade's Avatar
I think I will try something like these. What yall think?
Old 02-21-2007, 01:36 PM   #35
70rs/ss
70rs/ss's Avatar
For me, I need to buy new axels to go from 6 to 5 lug, so If I buy the 72 5-lugs, it sounds like the brackets'll work? I like the thick flange bracket, but since the stock flange is thinner metal, Glock I may need two sets of thin for the two thicks I got? LMK, no hard feeling, glad I saw this before I went out and had to throw stuff!!
70rs/ss is offline   Reply With Quote
Old 02-21-2007, 02:01 PM   #36
glock35ipsc
You might still be able to use the 3/8" brackets if you are using the earlier (shorts) rear end housing with later 72 (longer) axles. But if you still have a clearance issue with the thicker 3/8" brackets, i will send you a set of the 3/16" brackets no problem.
Bob
Old 02-21-2007, 10:20 PM   #37
Ram-Man
Ram-Man's Avatar
I hope I didn't open up a can of worms on this thread I took my rotors to the machine shop today to have that lip on the back taken off. As much as we all like a bolt on product it looks like to me that it would be a good idea to remove the inner lip on the rotors as 383stroker said just because it is so tight back there. The machinist said it would be a simple process to take it off. He offered to do it while I wait even.
Ram-Man is offline   Reply With Quote
Old 02-21-2007, 10:25 PM   #38
glock35ipsc
Keep in mind, and you should be able to confirm this once you have the thinner brackets, but you should gain another 3/16" clearance from the bolt head to that lip with the thinner brackets. Since they are 3/16" thinner, the head should set in another 3/16" away from the rotor.
I think
Bob
Old 02-21-2007, 10:32 PM   #39
jlaird
jlaird's Avatar
hey glock, what's the status on the camaro brackets? Did you get those calipers yet?
Old 02-22-2007, 09:45 AM   #40
383 Stroker
My rearend is the wider one with long axles. Here are some pictures.
