1972 Shorty Owner
Location: Stationed in Cali , born and raised in PHX Arizona.
Hello From Cali! - Lots of questions.
Hello eveyone,
I am new here but have been watching and reading this site for months. I just bought a 1972 Chevy C-10 Shortbed. She's very clean from what i can tell with only a little rust on the bottom of the doors and on the driver side corner of the cab. The motor is a 350 bored .30 over, TH350 tranny. I have a few questions if any of you would be willing to help me decide. The truck as of now has a automatic tranny, but still has the clutch pedal and the floor mounted shifter. I was wondering if any of you know what the damage would be if i converted the truck back to manual or if its even worth it. As far as i know, everything is stock besides the motor and the tranny. Also i was wondering if anyone knows how i could find out what the original sticker price for the truck was when it was sold in 1972. I found the original warranty in the glove box from the first owner with the metal plate still attached. I feel like i got a great deal for the truck when i bought her this week. I got the truck for 2k as it is. She runs great and sounds awsome. The guys mentioned there is a "RV" camshaft in the motor. Is that good or bad? I have a picture of the truck in my profile. I think the paint is original. I will post some pics up when i get home from work. Thanks in advance for any input! -Hart |
Re: Hello From Cali! - Lots of questions.
# 1 welcome to the site
# 2 Nice truck # 3 you stole it at 2K Where are you located? SFV here.
1970 Chevy C 10 SWB |
1972 Shorty Owner
I'm in the Navy stationed in Lemoore. Its near Fresno.
1972 Shorty Owner
I also had some questions about the gauge cluster. I am pretty sure that all of my gauges need to be replaced. The gas gauge deffinatley doesnt work, the speedometer needle just bounces around and my oil pressure gauge is always pegged at "H". my question is is it a better idea to replace the entire set? Should i just look at the wiring or the circuit board? I'm not to sure which way to go. I have seen some pretty nice aftermarket gauges but i'm not sure where to go to buy them or if they even will work in my truck.
I'm sure someone here can point me in the right direction. |
Welcome! Be sure to use the FAQ thread as it will answer and give you idea's on a lot of stuff. Nice truck also! and thought I got a good deal, your deal was smokin!
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=219094 |
______________
![]() Join Date: Sep 2006
$2K?! Are you kidding me? That's like clubbing a baby seal! Nice work.
![]() Join Date: Dec 2006
Welcome from Studio City,Cal. That's a real nice truck. The gauges I would inspect one at a time.The speedo possibly just needs a new cable.The gas Gauge may need a new sending unit (behind the seat,top-center of tank) or maybe just a new float or something. The oil Gauge may need replacement.
On a newly purchased vehicle I like to start by looking closely at the brakes,fuel lines,front suspension and other vital systems so I don't get stranded (or killed). The RV cam will give you better low-end grunt at the expense of high rev horsepower.I had one in my last '69 and it was incredible up to about 4000 RPM,then quickly ran out of steam.-Brian
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. |
Cool! Well nice truck, you did good!
Big Block
Very nice truck for 2K. You got a great deal.
To The Levy
If you only paid $2k for that shorty, you deffinately stole it, good deal,
As far as the gauge issue goes, I would check one at a time, the oil gauge is completely seperate , it runs a line to the engine at the back of the intake, if it is reading pegged all the time and never moves , even when shut off, I would suspect the gauge is bad, as far as gas gauge, the sender plugs into the fuse panel , labeled fuel, I think, I would check to see if its plugged into correct position, and if so , I would sweep test the sendor, remove sendor and with key on move the arm slowly to see if it matches the movement of the arm, some use brass floats on the end of the arm , and if the float gets a pin hole , it will fill up with gas and never float again, your gauge will read empty all the time, Speedometer, I would try lubing you cable , If that dont work you could check the cable by hookin up a drill and spin it while someone watches the speedo head, you may go reverse on the drill to read correctly , cant really remember, this will elimnate any gear issues you might have on the extension housing gear or speedo drive gear. if all is still not working on the speedo, you may want to check to see if its completely hooked up on the back of head, if so, sounds like maybe a head problem. I (my own prefference) would leave the auto and remove all the reamins of the manual. thats my opinion only. Rv cam's were just a way to call a one step above stock, maybe alittle longer duration and a little larger lift. these cams were usually used by people that wanted a little extra ooomph. without having to degree a cam or do the math to verify if valve to piston clearance was an issue , they could bet they were playn it safe with just using an rv cam. |
Designated A-hole!
Welcome to the board from South Mississippi!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
1972 Shorty Owner
Thanks for all the help guys! I am going to open up the gauge cluster today and try the gas gauge tip that hvychve recamended. Also you mentioned that the oil pressure gauge feeds from the the intake. Could this be an intake issue?
What about after market gauges with better lighting ...anyone know of a good site i can check out or do any of you use after market gauges ..... if so which ones ...pics? |
Sweet truck, 2K is a deal and a half. I can't imagine that's original paint though, since you don't have side markers in the bed for starters. Plus it just looks too nice to be 35 years old.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
Nice truck!! Must be in great shape from living in California. Dunno if its the weather but, IMO I would wet sand, polish then wax that thing. My truck had that oxidized look when i first bought mine, looks great now. Good luck with the gauges (mine were the same condition) I replaced mine because i didnt think about troubleshooting them. But now looks "nicer" whenever i look at my cluster.---Andy
1972 Chevy Truck 350ci/th350 Auto. Daily Driver ![]() Last edited by As2rd; 02-23-2007 at 05:33 PM. Reason: Almost gave the same instructions as above, DOH! |
#15 |
whats a wrench
very good deal
69 longhorn 350 headers 4 on da floor |
#16 | |
1972 Shorty Owner
Well your probably right about the paint. Dont let the pic fool you though ... it was rainning that day and the paint has zero clear coat. Its like a primer texture now. Back to one of my other questions. Do any of you happen to know what the sticker price was for these trucks when they were sold back then. I cant seem to find this info anywhere .....first time google has ever let me down! -Hart
1972 Chevy Shorty C-10- Project In Work http://67-72chevytrucks.com/gallery/...ATT1721941.jpg- New Project |
#17 |
"Taste It"
Drive it like you stole it!! cause you did.
Nice truck and welcome Brian
71 Chevrolet short fleet Cheyenne air cab/tilt w buddy buckets pretty stock other wise. ![]() ![]() 2007 Silverado Crew with the MAX Pack and loaded 2007 CX-9 "Hopefully when I die.. my wife wont sell my stuff for what I said I paid for it" It's easier to ask forgiveness than it is to ask permission. ![]() |
#18 | |
"Taste It"
![]() ![]() ![]() ![]() ![]() Joking I don't know. Brian
71 Chevrolet short fleet Cheyenne air cab/tilt w buddy buckets pretty stock other wise. ![]() ![]() 2007 Silverado Crew with the MAX Pack and loaded 2007 CX-9 "Hopefully when I die.. my wife wont sell my stuff for what I said I paid for it" It's easier to ask forgiveness than it is to ask permission. ![]() Last edited by bcanini; 02-24-2007 at 09:58 AM. |
#19 |
Keep On Keepin' On
#20 |
The Best Member
AWESOME find for 2k!!! Im originally from Fresno, currently serving in the Army right now. Make sure to hit up early classics its in Fresno and they can answer any questions you may have and they have every part you need for a resto!
70 shortbed C10 -------SOLD------- 1972 Chevy C-10 l/b |
#21 |
Welcome to the site!!!
and i agree that truck was a steal. ![]() I just got out of the navy last june, DC2 (SW/AW).
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill |
#22 |
good looking truck. for the guages try jeg.com or summit.com otherwise for stock look up venders on this site. tons of them. great for restoring original look. did that 2k come with a title, is it salvage. NO! then you just stole from that poor 2k richer little old lady.
#23 |
SLOW BUT SURE,BUT CLOSER
Goes to show one can find a deal once in a while!!!! Congrats and welcome
69 C-10, OWNED 35YRS... 350 over 30, 350 Turbo, 3:73 Posi P/S, P/B Black with red and black int. ''LOVE THESE OLD ''TRUCKS....... ![]() ![]() ![]() |
#24 |
1972 Shorty Owner
Thanks again everyone .....
Yes i have the title and no its not a salvage title ... I was thining about digital gauges also but thats later on. Right now i just want working gauges so i know my truck is safe. I still cant beleive i got it that cheap. I low balled the guy a bit, made the offer and he accepted. I have been trying to get the guy to sell it since October! He finally broke!
1972 Chevy Shorty C-10- Project In Work http://67-72chevytrucks.com/gallery/...ATT1721941.jpg- New Project Last edited by JHART; 02-24-2007 at 10:28 PM. |
#25 |
very nice truck..as stated drive it like you stole it
