Exhaust?
I was wondering about running my exhaust. I want it above the frame and I don't have a drop crossmember in it right now. I was think about hedmann elite shorties and then going to a magnaflow on each side like this
http://store.summitracing.com/partde...5&autoview=sku Then straight to a turn down. Anybody done this, I am thinking there is enough room, but I am also pretty sure it is going to be super loud. Any help thanks.
1970 Chevy C10 "Under Construction" ![]() 2002 Chevy S10 V6 ![]() |
![]() Join Date: Aug 2005
Re: Exhaust?
How far back are you putting the mufflers/turn downs? It sounds from your post like they're gonna wind up under your cab. I'd avoid doing that if I were you. Noise is one concern but you also gotta worry about exhaust creeping up into the cab too.
Re: Exhaust?
This Is How Mine Looks Now, I;m Goind To Move The Mufflers To The Out Side And Sound Deton The Cab This Should Help With The Clerance When I Bag It. Hope This Photo Helps. Good Luck
1972 c/10 Custom, Long Box, 350 Small Block, Auto 3 Speed, Custom Wood box, Full Air Ride, 3" C-Notch, 20" Front & 22" Rear Tires, Snow White Paint, PT Crusher Handles, ![]() |
Re: Exhaust?
OK, hmmmm. I didn't even think of the exhaust fumes. Good point. I am going to bag it is why I need it too be above the frame. Maybe I will just break down and buy the Early Classic Drop Member. And then run it thru their holes.
Chief Honcho In Charge
Re: Exhaust?
What is sound deton?
1992 1500 4x4 Shortbed 1984 Ford F250 Supercab Longbed 6.9L Diesel 1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C 1971 VW SuperBeetle 1960 Wife 1984 Son 1986 Son 1989 Son Previous Trucks 1967 C10 SWB (1980-1981) 1971 C10 LWB (1998-2004) |
WTB this ad
Re: Exhaust?
Do a search for exhaust and look for a thread by member 71see10 (or search member 71see10). He has a thread with plenty of pics of the Hedman Elites and his exhaust being tucked above the level of the bottom of the frame. His exhaust was also ran through the trailing arm xmember.
#7 | |
In Memoriam...
Re: Exhaust?
Thought about a cross-over (X or H pipe)? They will help to decrease volume a little, will smooth out the burble, and give ya' 1 or 2 extra ponies... ![]()
'68 C10 SWB 307ci 2BBL FarmTruk Pics Here "You know, doing what is right is easy. The problem is knowing what is right." |
Re: Exhaust?
i had my truck exhast dumped under the bed and it just got so loud i finally decided to re rout it out the side b4 the rear wheels. it has two flowmaster 40 series and long tubes. it was even really loud with dynamat inside the whole cab under the carpet. now its fairly quiet inside with the pipes coming out the side.
'69 C10 SWB 350 edelbrock int/carb .420 .442 cam 700r4 70 lwb c10 work truck 250 I6 with two inch lift springs and a two inch bodylift and 33/12.5s |
Re: Exhaust?
i believe people hav cut holes into their stock cossmember to fit pipes through.. im not sure though. it seems possible...
blood type; Retumbo
Re: Exhaust?
I just had mine done on wednesday. I'll bring a camera to work today and post pics Saturday. it runs through the Xmember with a little help from the blue-tip wrench.
Re: Exhaust?
Re: Exhaust?
On My Truck I Have A Ragged System Connected To Some Ragged Left Over Race Car Headers. I Have A Set Of Rams Ceramic Coated Ready To Go On. I Need The Front Pipes That Connects To The Ram Manifolds And Goes Down Just Under The Cab And Temorarly Tie On To My Current Exhaust. Does Any One Have A Set Of Front Pipes Just Long Enough To Replace Where My Headers Stop That They Want To Get Rid Of? I Just Need Them Till I Get The Cash To Replace The Rest Of My Exhaust.
1972 C-10 SWB 350CI TURBO 350 TRANNY, TILT, POWER WINDOW & BRAKES, TANK UNDER THE BED W/MARKER LIGHT FILLER. 3.08 GEARS, CLASSIC AIR ![]() ![]() 2000 chevy blazer 1990 nissan pick-up 1984 mazda pick-up (son's project truck) |
Project underway - finally.
Re: Exhaust?
X pipe will quiet it down some and mellow the tone. Turndowns are cool - it depends on what you're driving over ie, they are very quiet in snow and very loud on concrete. Don't end it under the cab - I did that and all of the people in the truck smelled like gas when we were finished. You could still turn it down before the axle to save space, but get it as far back as you can.
My opinion though. Headers and mufflers and turndowns are quiet enough for me and sound mean. Plus, how many muffler tips have you seen that you actually liked? -Brian
1972 GMC Pre-resto... awaiting allocated funding. |
Worthless
Re: Exhaust?
Here's a few pics of mine with 2 1/2 and hedman headers,cut thur the cross member,with a h pipe and out the back.Hides all of the exhaust.
#15 |
Re: Exhaust?
71see10 what did you use to cut the crossmember?
#16 |
Worthless
Re: Exhaust?
I had a man that does fab. work at his home and he also does custom exhaust work do this,he used a plasma cutter.Very clean cut!!!!
#17 |
Re: Exhaust?
