Old 02-15-2007, 06:30 PM   #1
jon6.0
New(to me) 72 3-door K10 Suburban w/ pics
So originally I was looking for another 68 Impala Fastback like I used to have years ago. Then I came accross this Suburban for $2100. It has a 350 with Holley aluminum intake, chrome Holley 4 barrel, headers of unknown origin, tiny 1 3/4 or 1 7/8 dual exhaust, Turbo 400 transmission, don't know what T-case. Has factory dual AC. I am not sure if I want to mess with trying to get all the AC going again. I know I want AC in the front at least, just not sure how much it will cost to get the rear AC going again. It needs a new interior and I just so happen to have a 20% off coupon to Classic Industries. It needs a headliner, dash pad, door panels, new carpet, and seat upholstery. It runs real well except for a slight hesitation off idle. The previous owner took the tilt wheel out of it which I am kind of po'ed about. The gear shift indicator doesn't line up. The drag link was shot when I drove it home so it steered all crazy for the 80 mile drive home. Got that fixed this morning and it steers great now. My temp gauge isn't working so I bought a new sender from NAPA, so hopefully that will fix it. Also the gas gauge doesn't work, but according to the previous owner it was working a couple weeks ago.
1972 3-door K10 Sold and now looking for another one
2005 Pontiac GTO
jon6.0 is offline   Reply With Quote
Old 02-15-2007, 07:10 PM   #2
bagged91
Out draggin'
bagged91's Avatar
Re: New(to me) 72 3-door K10 Suburban w/ pics
Nice solid looking burb... The rear A/C shouldn't be too hard to get working as long as the hoses are in decent shape. The actual unit itself is the same as the 73+ rear A/C burbs... What are your plans for her?
Oh, and Welcome to the board from icy NJ!
91 GMC Xcab LB-Bags/bd/caddy clip SOLD
72 C10 Cheyenne Super LWB SOLD
92 GMC K1500 Burb
72 C10 Burb (ex. Cheesewagon)SOLD
72 C20 Burb parts truck
71 C10 Burb "project"
bagged91 is offline   Reply With Quote
Old 02-15-2007, 08:35 PM   #3
jon6.0
Well since I found out I knocked up my fiance the 2000 Ford Ranger I bought her isn't going to cut it in 8 months. So I started looking for an Impala and ended up with the 'burban. As soon as the Ranger sells I am going to have the passenger side rocker panel replaced and redo the whole interior with new stuff from Classic Industries. I can't decide if I want to put carpet back in it or just do the rubber floor. I am going to put white doorpanels and rear panels in it with a white perforated vinyl headliner. Also going to do white vinyl seats with sheepsking seatcovers over them for the Phoenix 120F summers. Then the next step/at the same time is getting the AC system working. The hoses going to the back look to be in place but may need to be replaced. I also need to replace all seals and weatherstripping. After all that gets done I am going to take the trim off the sides and have it repainted with the original color scheme. Just without that goofy trim on the side. I am also going to have the antenna hole plugged and smoothed over. I don't need to pick up regular stations since I will be using Sirius in her.
Does anyone know where I can get a replacement cover piece for the rear AC unit? Also where to get the rear inside panels?
-Jon
2005 Pontiac GTO
Old 02-15-2007, 10:04 PM   #4
70gmcburb
nice burb! i got my 70 4x4 burb 6 mo. ago and the fuel gauge did not work. i pulled out the sending unit, found the float leaked (full of fuel) got a new float from grumpys.
luis
70gmcburb is offline   Reply With Quote
Old 02-15-2007, 10:31 PM   #5
jon6.0
Who is Grumpy's??? Do they have a website?
2005 Pontiac GTO
Old 02-15-2007, 10:54 PM   #6
70gmcburb
there in phoenix. website? try grumpy's truck parts. not cheap but they are local.
Old 02-16-2007, 12:09 AM   #7
ABHaulR
ABHaulR's Avatar
i replaced all the a/c lines in mine, it took 43 feet of line to do the job. had the lines made up at a local shop for around 200.00. that included all new fittings. its the freon that kills you. a dual system takes about 6.5 lbs of freon. its been awhile but its around there.
Dwayne
72' GMC Suburban 10 1/2" of Lift, 40" Tires! Waiting for restoration
67' Chevy, What to do???
And Bad Ass American Bulldogs!
ABHaulR is offline   Reply With Quote
Old 02-16-2007, 12:11 AM   #8
ABHaulR
ABHaulR's Avatar
heres my 72 gmc
Old 02-16-2007, 10:22 AM   #9
92306HO5
92306HO5's Avatar
just saw that in the trader.great deal and nice burb...
92306HO5 is offline   Reply With Quote
Old 02-16-2007, 04:01 PM   #10
bagged91
Out draggin'
bagged91's Avatar
Does your burb have the woodgrain on the doorpanels?
The rear A/C cover is not reproduced... A little creative fiberglassing can repair the one you have.
Rear cargo panels are available new but only in black and they are NOT CHEAP.... I have white & blue 72 cargo panels...
PM Sent on the rear panels
92 GMC K1500 Burb
Old 02-16-2007, 08:08 PM   #11
jon6.0
No woodgrain on the panels. I am interested in your parchement rear panels. I am still waiting to sell my Ranger, so take your time with the pics. I know nothing about fiberglass. Can I just take the existing rear AC cover off and have a copy made? What would that cost me?
2005 Pontiac GTO
Old 02-17-2007, 12:45 AM   #12
bad_turbo
turbo enthusiast
bad_turbo's Avatar
can never get enough pics of the 67-72 burbs
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting "
bad_turbo is offline   Reply With Quote
Old 02-17-2007, 08:30 AM   #13
You done good.You should subscribe here.Then,you can put a WTB post on here for the rare non-reproduced stuff.It`s amazing what guys can come up with here.
Old 02-17-2007, 05:13 PM   #14
RANDY COX
RANDY COX's Avatar
Nice lookin burb I'm kinda partial to burbs,Looks like it already has a lift on it.I'm lookin around for tires 33's.I already have a offy intake and soon be adding a holley 390 or eldebrock 500 4-barrel,and hopefully a set of headers,that ought to wake up the ole six-banger a little.Hey special-k where have you been.
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 02-17-2007, 06:15 PM   #15
jon6.0
Thanks for the compliments on it. ABHaulR that is one sweet rig you have. Just got home from work and I am fixing to replace the temp gauge sending unit. Hopefully that's why it doesn't work. Do I need to drop the gas tank to get the sending unit out? Are there some wires I can wiggle first?
2005 Pontiac GTO
Old 02-17-2007, 08:21 PM   #16
You can pull on them,but it`s tight on top.I wonder how your printed circuit is on your cluster,with two gauges out.
Ask ABHaulR about his rear suspension,truly unique and way cool.
Randy,I`ve been on a top secret mission.If I told you,I`d have to kill ya.
Nah,computer problems.
Old 02-17-2007, 10:47 PM   #17
jon6.0
I put that new temp sending unit in and now I have a working temp gauge. Stays just barely to the right of center.
ABHaulR, what's your rig have for rear suspension?
2005 Pontiac GTO
Old 02-22-2007, 12:05 AM   #18
da-burb
"Ochre Ogre"
da-burb's Avatar
That is a nice looking suburban and a real nice price. I am just a touch partial to the color too............
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 02-24-2007, 04:00 AM   #19
stsalvage
Scrapper 1
stsalvage's Avatar
i'm still looking for the 1968--1972 car hualer with the steel 15-18 foot bed with rollers and a winch that is the dream truck been looking at the 1965 3 ton and looked at a 1972 3 ton roll back tow truck might have to do some converting to make it a sweet truck
stsalvage is offline   Reply With Quote
Old 02-24-2007, 09:39 AM   #20
mvpco
I agree I love the color too
Jeff Smith
Pensacola, FL
mvpco@yahoo.com
mvpco is offline   Reply With Quote
Old 02-24-2007, 11:37 AM   #21
jon6.0
The girl and I agree that we are going to keep it the stock colors. I was thinking of going with PPG paint. Does anyone know the paint code for our ochre trucks and the white top?
2005 Pontiac GTO
Old 02-24-2007, 02:54 PM   #22
Da-Burb should change his name to Ochreman .He`ll prolly chime in for ya.I wanted to buy a GMC like yours,but couldn`t swing it.It was $5,500.
Ok,I`ll spill the beans on ABHaulR`s rear suspension.He started with a 2wd Suburban and it`s got the trailing arms/coil suspension.Purdy dang kewl,I think.
