Old 02-25-2007, 10:36 PM   #3
Jdog44
Jdog44's Avatar
Re: Steering colomn for 73 blazer
Originally Posted by beaterC10 View Post
Are you saying the column in the 73 has the square shaped end? A 73 would have had a splined column from the factory. You can use either column if you find the mating intermediate shaft. I don't know for sure if the wiring is the same or not, but that wouldn't be too hard to check.
Yes the 73 has the square end. I was told the 73 should have a splined shaft but it doesnt. So i will look for a splined shaft at the junk yard since we would rather have the tilt. And the mid 80s column doesnt look like it will work . THANKS
72 k5 cst
Jdog44 is offline   Reply With Quote
